April 18, 2026, 12:48:09 AM *
Pages: 1 ... 71 72 [73] 74 75 ... 89
Author Topic: New Olds (boat tail speedster)  (Read 588277 times)
« Reply #1080 on: August 10, 2016, 09:31:47 PM »
i used ,FLUXOVITE, paste in a tin,,or,BAKERS, solering fluid . when i used to do it years back
« Reply #1081 on: August 11, 2016, 06:53:24 AM »
With more gas, managed to get the tinning almost finished. Pic also shows the new 5mm diameter safe edge welded in place.
Safe edge on the rear of the mudguard ?  I'm surprised they don't want a rubber bumper around the complete vehicle ( ala bumper cars ?)
Nice work though Mr P..
« Reply #1082 on: August 11, 2016, 07:23:22 AM »
God forbid that anything be less than rounded. That gearlever I spent so much time forging is a definite no-no. Sad
I used Bakers Fluid flux, capilliary solder for tinning and what I think is 60/40 lead/tin as a filler. Not sure as to the exact makeup as the bar is probably 40 years old and the makers don't use the same numbering system anymore.
I have used standard lead fee solder and this is OK but has a narrow temperature band between solid and liquid. Makes it hard to keep at the butter stage, but is healthier for you to work with.
« Last Edit: August 11, 2016, 07:36:41 AM by Olds » Logged
« Reply #1083 on: August 11, 2016, 08:38:35 AM »
another dying art, I spent three months as an apprentice in the lead work depot. Spent most of it learning to make solder nipples for Arrestor wires on aircraft carriers. I still get the odd call to repair lead pipes, and make roof flashings etc. Lead is now considered bad for you even in small quantities. Along with cadmium brazing, arsenic in copper, I'm surprised I'm still kicking or have I built up an immunity  Grin
Mendalot
« Reply #1084 on: August 11, 2016, 09:41:52 AM »
In the video I watched yesterday, he was using Tinning Butter, which is a paste with acid and lead particals mixed in. The surface is heated and the paste rubbed over with a copper dish scourer held in mole grips, the effect was instant tinning. This is the vid, if anyone is interested ... https://www.youtube.com/watch?v=87fuTnBS2bE
« Reply #1085 on: August 12, 2016, 01:56:33 PM »
Not going to go through it all with the second mudguard except to show that, to try to get the rear flare to match the first (well nearly), after slitting the mudguard I bent the 5mm safe edge hoop, welded it at the ends then beat the mudguard out to meet it. Just need to make and weld in the infill sections.
« Reply #1086 on: August 17, 2016, 02:35:07 PM »
Due to difficulties in ensuring that all those bonnet louvers meet iva requirements I will probably have to cover them or make new bonnet tops.
Prototype hammered out of aluminium sheet. Think I need to simplify the design.
« Reply #1087 on: August 17, 2016, 06:02:42 PM »
I think you're way too clever.  Sad
Mendalot
« Reply #1088 on: August 17, 2016, 09:40:41 PM »
Blimey Dave!!!  Thats a work of art.  Mr IVA man may not notice anything else when he see's those Grin
« Reply #1089 on: August 24, 2016, 01:35:03 PM »
I wish, but thank you. Cheesy
If I go ahead with this, I have to make twelve of these.  Sad Six pairs graduated in width, from 4" to 8" so to have any chance of them looking remotely similar, even if simplified, I figured that a hammer form would be required to shape the metal over.
Pic shows it being roughed out from a slab of 20mm thick steel. Not sure how well this will work. Undecided
« Reply #1090 on: August 24, 2016, 06:46:59 PM »
I think you shouldn't worry to much about being perfect..let people see the slight difference it gives it lif/soul/character sir..bloody great work
« Reply #1091 on: August 24, 2016, 08:30:01 PM »
Lots of scope for what you call life/soul/character in making these even with the hammer form. All it does, is allow me to form the corners with some degree of repeatability. Making relatively tight radius compound curves in sheet aluminium is awkward.
Tester
« Last Edit: August 24, 2016, 08:42:17 PM by Olds » Logged
« Reply #1092 on: August 24, 2016, 09:41:54 PM »
We all know how it'll work Dave -bloomin' annoyingly perfectly, as always. I suspect you've done a deal with the Devil for your skills Sir.
« Last Edit: August 26, 2016, 06:34:38 PM by Manky Monkey » Logged
« Reply #1093 on: August 25, 2016, 07:16:06 AM »
 Grin Grin Grin
« Last Edit: August 25, 2016, 04:20:32 PM by Olds » Logged
« Reply #1094 on: August 31, 2016, 09:53:12 PM »
Trying to get my head around sizing the dual circuit master cylinder.
If I go for two seperate master cylinders with an adjustable balance bar I would just half the cross sectional area of the existing master but with a dual circuit cylinder with it's equalising ports etc. it's not making sense.
Perhaps I'm just tired.
