April 26, 2026, 04:53:40 AM *
Author Topic: reliants breathing  (Read 2516 times)
twisted
« on: July 18, 2014, 02:17:06 PM »
anyone with a reliant trike, question. do you have much smoke/steam that comes out of the breather cap? is it pretty constant? do you have the standard cap, modded or a pipe down the frame to the deck to loose it?
only asking because i can see smoke/steam coming from mine. i have set up another bottle on the side of my frame with a tube from the modded breather (right angled with no filter/gauze in it) going into the top and a small hole to let out pressure. i done this so i could check to see what/how much stuff came out after my head gasket change. as i ride i can see smoke coming out the hole i drilled and wanted to check this is normal before i run a pipe down the frame and forget about it  Smiley
« Reply #1 on: July 18, 2014, 03:39:17 PM »
Is it smoke or steam ?
Before replacing my head gasket, I could set fire to the vapour coming out of mine, like a Bunsen burner  Shocked. Now there is very little coming out of the standard breather (nothing visible) and is connected to the carb.
« Reply #2 on: July 18, 2014, 04:04:24 PM »
After much time / experimentation re-routing the rocker cover breather pipe , I reverted back to connecting the rocker cover breather hose directly to the spout on the side of the carb , as per early Robins .
« Reply #3 on: July 18, 2014, 07:38:28 PM »
The rocker cover breather pipes on my V8 are routed back into the air filter. Works fine.
