April 29, 2026, 06:24:47 AM
What's missing?
Topic: What's missing? (Read 2727 times)
What's missing?
February 08, 2014, 07:24:07 PM »
Ok, so what is missing from this picture?
Chevy Rick
Re: What's missing?
February 08, 2014, 08:22:46 PM »
The Reliant name cast on the crank case?
Re: What's missing?
February 08, 2014, 09:26:47 PM »
Yep.
Got fed up with people looking at it and then asking, what make of engine is it?
At least now they have some excuse for not knowing.
Re: What's missing?
February 08, 2014, 09:42:39 PM »
Planning on doing the same to the Reliant motor in Loony & my T bucket roadster. We'll probably get Loon's Dad to mill the lettering off. What method did you use Dave?
Re: What's missing?
February 08, 2014, 09:58:38 PM »
Nothing as high tech as a mill !
Mallet and chisel, followed by a wire brush in a drill. The ally is so soft that I used a small wood chisel.
Re: What's missing?
February 08, 2014, 10:23:49 PM »
Ooh! That'd have Cracked Casing written all over it if I tried that!
Re: What's missing?
Reply #6 on:
February 09, 2014, 08:56:13 AM »
Hi o n
What's that box shaped item that the coil bracket is bolted to?
Re: What's missing?
Reply #7 on:
February 09, 2014, 09:14:04 AM »
It' just a cover for the starter motor and associated wiring. The later starters like mine are the pre engaged type, with a big solenoid attached. This hit my ankle and also looked pugly.
klogan45
Re: What's missing?
Reply #8 on:
February 12, 2014, 07:59:22 PM »
A scantily clad female?
Re: What's missing?
Reply #9 on:
February 12, 2014, 08:16:13 PM »
Quote from: klogan45 on February 12, 2014, 07:59:22 PM
Bit cold in the garage for that sort of thing. But I can always dream.
Re: What's missing?
Reply #10 on:
February 12, 2014, 09:49:55 PM »
Looking really neat .
Just a wee suggestion regarding the fuel pump .
If that is the plastic top version I would change it soon as possible due to the fact that a good few owners have had the pipe stubs come loose and , in one case I know of , detach completely !!!
What is a scantily clad female
