April 23, 2026, 12:19:01 PM *
Author Topic: Air compressor  (Read 7439 times)
« on: December 28, 2013, 03:19:54 PM »
I'm looking at buying a compressor and I've come across a couple of used ones on ebay that keeps blowing fuses so they selling them as spares or repairs.
Would any one have an idea why this would be the case and would it be an easy fix
Thanks,
Merv.
andbolt0
« Reply #1 on: December 28, 2013, 03:25:12 PM »
replace the fuse with an m8 bolt or  a much safer way would look at the cost of a replacement motor
« Reply #2 on: December 28, 2013, 04:45:39 PM »
Hiya Merv. Any idea what size the motors are?
The larger motors will pull a higher current at start up than a standard 13amp socket can supply and need to be fitted on a seperate dedicated circuit, although this should be written in the instruction book, how many of us read those.
Or....
Compressors need to be started 'off load', if they are switched off at the socket rather than the on/off switch fitted to the compressor, the de loading valve will not operate and maintain full pressure load on the motor which in turn will draw more current as it attempts to start.
Or.....
It could be knackered!
« Last Edit: December 28, 2013, 04:47:15 PM by tbone » Logged
Mendalot
« Reply #3 on: December 28, 2013, 05:16:19 PM »
Hi Merv, I have a good one for sale, was waiting for the new year to advertise it. I will put a picture and details on here on Monday when Im back in the workshop. It is one of the space saving types, where the motor and twin pump sit on top of a tank endways. so can stand in a corner.
Paul.
« Reply #4 on: December 28, 2013, 11:14:51 PM »
This is the one its  3 horse power,
http://www.ebay.co.uk/itm/Sealey-air-compressor-50-liters-/271337454930
« Reply #5 on: December 28, 2013, 11:45:46 PM »
I paid a lot less for a worker of the same size (not sealey). Looks like an expensive gamble to me Sad
New one here for less than 140
http://www.ebay.co.uk/itm/Sealey-Tools-SA5020-50L-50-Litre-2HP-Direct-Drive-Air-Compressor-New-Boxed/261134797739?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D74%26meid%3D3727181242761906612%26pid%3D100005%26prg%3D1048%26rk%3D1%26rkt%3D4%26sd%3D201007379779%26
« Last Edit: December 28, 2013, 11:48:11 PM by andyrennison » Logged
« Reply #6 on: December 28, 2013, 11:58:00 PM »
it dosn,t look big enough to be 3HP to me  Roll Eyes
i,v got a v,twin simaler and it only cost me £60 six months old and as clean as a whistle,,
« Reply #7 on: December 29, 2013, 12:12:10 AM »
Ill keep looking, some thing will turn up
Mendalot
« Reply #8 on: January 04, 2014, 11:19:53 AM »
Merv, I havnt forgotten about the pic of the compressor, I will be able to put it on on Monday.
Paul.
Mendalot
« Reply #9 on: January 06, 2014, 11:02:12 AM »
This is an oldie, nearly as old as me!!  but works fine Grin   150 psi working preassure, not sure of the CFM.
http://i390.photobucket.com/albums/oo343/PDSheridan/Photo06-01-2014104215Copy_zps7884faa7.jpg
Air compressor
http://i390.photobucket.com/albums/oo343/PDSheridan/Photo06-01-2014104251Copy_zpsdd806ce7.jpg
Air compressor
« Reply #10 on: January 06, 2014, 08:09:58 PM »
Well, you know what you are getting with an Ingersoll compressor, Quality! and the physical size of motor/ comp. looks right for the use......my compressor, as a matter of interest, I cobbled up 40years ago, using a double decker bus air brake compressor, and a 6' length of HD tube, with cap ends, as a reservoir! still going strong after all this time............Morrag
« Reply #11 on: January 07, 2014, 07:45:09 AM »
ive got 2 compressors, free. like everything o score, they dont work properly but its not worth paying someone to fix them
Mendalot
« Reply #12 on: January 07, 2014, 10:29:43 PM »
Hello Merv, would this compressor be any good to you? if not it will be going on Ebay next week Wink
« Reply #13 on: January 07, 2014, 11:18:19 PM »
Sorry Mendalot, thank you for the offer, I now have one.
