April 16, 2026, 11:14:07 PM *
Pages: 1 ... 6 7 [8] 9 10 ... 25
Author Topic: Kawasaki 750 hard tail (was rear end ratios)  (Read 163114 times)
« Reply #105 on: May 14, 2014, 07:19:49 PM »
Is that a reverse gear on the shaft I see?
I welded up the shaft, it seems to spin true without any wobble, guess I'll try it.
Thanks,
Huw
« Reply #106 on: May 14, 2014, 09:09:42 PM »
mmm, very interesting, you have no swivel at the diff end at all, and no slider since this was at the back. I wonder if the locating pin has been removed?
No idea about locating pin, I wasn't the builder.  The shafts line up just about perfectly as the axle is shortened.
Did you sell her BG?
Nope, but I'm still debating as I haven't used her much - still, hopefully we have a proper summer to come.  If someone madev me an offer I couldn't refuse I might - but it's not likely in these hard times.  And I do love her!
« Reply #107 on: May 14, 2014, 10:20:44 PM »
Master cylinder/pedal box thing:-
http://i65.photobucket.com/albums/h232/carreglasinimutly/mastercyl_zpsf0107555.jpg
« Last Edit: May 14, 2014, 10:36:09 PM by minimutly » Logged
« Reply #108 on: May 14, 2014, 10:28:16 PM »
From behind:-
http://i65.photobucket.com/albums/h232/carreglasinimutly/mastercylrear_zps63231914.jpg
« Reply #109 on: May 14, 2014, 10:34:40 PM »
In the frame:-
http://i65.photobucket.com/albums/h232/carreglasinimutly/mastercylinframe_zps4267aead.jpg
The propshafts old and new:
http://i65.photobucket.com/albums/h232/carreglasinimutly/props_zps413e8406.jpg
Back axle, short tube:-
http://i65.photobucket.com/albums/h232/carreglasinimutly/shorttube_zpse3949359.jpg
The long one is pretty similar....
All the best,
Huw
« Reply #110 on: May 16, 2014, 06:24:08 PM »
Damnit all why does photobucket insist on turning all my pics into portrait?
Anyway, shiney bits came today:-
http://i65.photobucket.com/albums/h232/carreglasinimutly/Photo0080_zpse831481a.jpg
Motad 4 into 1.
As suspected, there looks to be a clash with the master cylinder/pedal pivot, but I won't be certain until I bolt everything up. The headers are slightly smaller diameter (they were from a gpz550), but since I won't be extracting the last percentage of rpm out of the old 750, that shouldn't cause a problem - in fact it might improve mid range since it's a 4 into 1?
I'm planning a cut and shut, extending the system, using some thin wall 2 inch stainless milk pipe, anyone bent this stuff? Sand and a propane torch?
All the best, Huw
« Reply #111 on: May 16, 2014, 09:12:33 PM »
I ran Motads on my XS750s, as well as my XS850 & XS1100. Nice systems & seemed to give the best aftermarket pipe performance.
« Reply #112 on: May 18, 2014, 10:08:51 PM »
It's time to sort my axle out properly, that means setting the diff pre-load and backlash. Thanks Fifer for the reliant instructions, the gist of which are that reliant use dummy bearings, setting tools that mount on the backplate flanges, and a dummy pinion. Now while all this is possible to replicate, it seems kind of a lot of work for one axle.
My thoughts are that I could re-set the pre-load to something sane (if I recall I measured some 26 thou), then check ther's "a little" backlash and hope for the best. The difficult bit is removing and refitting the diff side bearings every time I need to change shims, bolt up the casing, and remeasure - kind of slow work.
Unless someone has any other suggestions?
Huw
« Reply #113 on: May 20, 2014, 10:54:04 AM »
Now bearing in mind that I've never built anything and don't really know what you're on about........
When my trike was built the builder sourced a reliant axle., shortened it, and built the trike.  Why does all that other stuff need doing?
« Reply #114 on: May 20, 2014, 03:55:57 PM »
Shortening the axle is easy (relatively), just shorten and reassemble.  If you change the diff inside the casing you have to set the bearing preload - I suspect mine had been changed at some point omitting this task. Also, you have to ensure the pinion meshes at the correct point on the crownwheel (it's a bevel gear so in/out as well as left/right is important). My pinion has worn to hell on one side, it still works, but how much extra drag it puts on who knows. So I bought a 2nd hand crownwheel and pinion to fit my diff, which as I started off with is over (pre)loaded between the casings.
Guessing all this is not good, but there is some paint out there which you can use to tell/tale the contact patch, I just need to find it. Some more research required I think.
Thanks,
Huw
« Reply #115 on: May 20, 2014, 04:52:28 PM »
Thanks,
Huw
It was yes
« Reply #116 on: May 20, 2014, 08:35:29 PM »
Ah I see, thanks for that!
Now that I CAN help with - I think this is what you're after...  "Engineer's Blue"
http://www.amazon.co.uk/Miscellaneous-Tin-of-Micrometer-Blue/dp/B005LV1YVC/ref=sr_1_1?ie=UTF8&qid=1400617958&sr=8-1&keywords=engineers+blue
« Reply #117 on: May 24, 2014, 10:11:23 PM »
I bought a gt 550 motad 4 into 1, assuming it would fit. We'll surprise surprise it didn't. So it came down to buying another and selling mine on, or lengthening my down pipes. Being a tight fisted git I decided to go for it with the thin discs.
The result, I had to lengthen the two near side tubes. Used some stainless pipe, slotted, drilled and welded through. It looks ok, I must say, pics tomorrow. I also found some Astra 16v front pipe which has the necessary kink to pass the brake master cylinder. More stainless welding tomorrow then...
Huw
« Reply #118 on: May 24, 2014, 10:47:32 PM »
A lot of people think the 550 and 750 have more in common than they do - even ther frame is different!
« Reply #119 on: May 25, 2014, 07:26:50 PM »
nice chrome 550 headers:
http://i65.photobucket.com/albums/h232/carreglasinimutly/Photo0084_zps6ef2a590.jpg
See the lengthening tubes ?:
http://i65.photobucket.com/albums/h232/carreglasinimutly/Photo0085_zpsf669ab4b.jpg
Now to finish the axle.
All the best,
Huw
