April 22, 2026, 11:25:38 PM *
Author Topic: a breath of fresh air  (Read 2451 times)
« on: November 14, 2013, 09:55:26 PM »
ok so painting time is approaching and I've been gathering supplies so far the list is etch primer, 1k high build primer and a synthetic black for pedals tin ware etc for the frame I'll need either 2k or water based for the frame and fibreglass bits, the paint will probably be waterbased as that's what i sell in work but the primer and lacquer are 2k , my compressor (or budget) won't run to an air fed mask so what are the alternatives.
we sell mouldex 8000 series masks in work and are told they a suitable for 2k but I'd like to be sure,any thoughts
Eddie
Mendalot
« Reply #1 on: November 14, 2013, 11:42:36 PM »
What about cellulose ?
« Reply #2 on: November 15, 2013, 07:13:26 AM »
not readily available over here now,we haven't been able to get a binder for our ppg scheme for about 4 years now and i would like to mix a custom colour myself
Mendalot
« Reply #3 on: November 15, 2013, 08:07:43 AM »
Yes it is getting hard to get now, I get my celly from Jawel Paints in Birmingham, by post, they will mix any colour you want, can even send them a sample and they will mix the colour for you. can have it in 400ml aerosol cans or by the litre. You must state that it is for restoration purposes.
Paul.
« Reply #4 on: November 15, 2013, 08:45:15 AM »
The moldex 8000 series mask is the mask I've used for the past 8 years using 2k paint just make sure you have the correct filters fitted to it
Mousy Boy :-) AKA Mick Smiley
« Reply #5 on: November 15, 2013, 09:07:04 AM »
Thanks for the info ,both good options . If the mask work's ok I'll go that way the filters on this one is a1? What do you use Mouse?
« Reply #6 on: November 15, 2013, 09:24:17 AM »
I will check shortly for mate
« Reply #7 on: November 15, 2013, 09:36:18 AM »
http://i31.photobucket.com/albums/c355/007mouse/DSC03013_zps1d06dced.jpg
its a A1 mate
« Reply #8 on: November 15, 2013, 11:57:24 AM »
Cheers Mouse
