April 22, 2026, 10:22:39 PM
General Tech
A bit of Reliant info needed
Topic: A bit of Reliant info needed (Read 2954 times)
brock
November 13, 2013, 08:19:49 PM »
Anyone in the position to take a couple of measurements for me ?
I need to know how much throw I need to build into the clutch pedal , how far does the clutch lever on the box need to move ? either in degrees of rotation or horizontal movement and lever length .
Hand brake , how far does the lever on the backplate need to move .
Any and all info gratefuly recieved , thanks
Re: A bit of Reliant info needed
November 13, 2013, 09:01:47 PM »
Clutch arm = 147 between centres, normal movement =35mm, movement required to disengage clutch =17 to 20mm approx.
Handbrake arms movement will depend on adjustment but mine are about 4 to 5mm at clevis.
Hope this helps.
November 13, 2013, 10:15:33 PM »
Normal clutch pedal ratio is around 4 or 4.5:1 ,same as standard automotive brakes.
brock
November 13, 2013, 10:17:32 PM »
Spot on , thank you both
