April 23, 2026, 10:12:28 AM *
Author Topic: messing around trying to start reliant trike engine???.  (Read 2968 times)
slug
welsh borders biker
« on: November 07, 2013, 03:17:52 PM »
 Smiley :)messing around with reliant trike today, charged battery,,
cleaned solenoid , managed to get engine cracking over on starter.
cleaned plugs checked for spark all ok..put temp pipe in can too fuel
pump, then piped up to carb,, fuel was not pumping through engine fuel
pump to carb.. checked carb float needle freed that off.  put fuel in direct into
float bowl,, got engine to fire up a few times for a couple of seconds..engine
did not sound to bad, now loud noises,, little bit of smoke.. not bad as been stood
for a few years,,seem to have small leak of fuel from bottom of  su carb float
chamber,, its the strange flex pipe that goes from float to main carb body, it has
the needle slide also all one unit..could be running down pipe from needle end..Huh any tips how to seal or any one got spare..
seems funny the way its is fitted into float body.. cheers the slug Smiley Smiley Smiley Smiley Smiley Roll Eyes
« Last Edit: November 07, 2013, 03:19:31 PM by slug » Logged
« Reply #1 on: November 07, 2013, 04:43:34 PM »
It is almost certainly leaking from the float bowl connection.
Fitted to the pipe should be a tube nut, a small washer and a rubber gland. This gland tends to perish/dissolve with modern fuels. Luckily they only cost 80p each from moss-Europe. part number AUD2194
slug
welsh borders biker
« Reply #2 on: November 07, 2013, 05:01:59 PM »
 :)cheers old newbie will send for one thanks,,. Smiley Smiley
your a star thanks for advice.. Smiley :)made a temp one from
tap washer cut down..id hole correct for tube tight fit over ferula
trimmed outer edge to fit..   Huh 8)asked about trike log book.,
has not arrived yet,, if its reg correctly should say.  tricycle on
body type..Huh. Cool
« Last Edit: November 07, 2013, 05:30:42 PM by slug » Logged
« Reply #3 on: November 07, 2013, 07:38:52 PM »
When you say you asked about the log book - asked who?  I thought you got the 'new keeper' bit?  You're supposed to send that to DVLA.
You can also apply for a new one if you tell them the old one is lost.
slug
welsh borders biker
« Reply #4 on: November 07, 2013, 07:57:10 PM »
 :)hi biker gran,, no don't have full log book yet..
there were two reliant trike on ebay ending today both
were not q reg,, so asked in questions what was on there
log books for body type,, because they both said in ads there were correctly registered,
both came back with reply body type listed as tricycle. (trike).. Smiley
sorry only got new owners bit.. at moment the small green bit..
« Last Edit: November 07, 2013, 08:02:40 PM by slug » Logged
« Reply #5 on: November 07, 2013, 08:11:10 PM »
The logbook ought to say just Motor tricycle, but it's more than likely got the Reliant's original chassis number stamped onto the new trike frame -which is completely illegal & makes it a "ringer" -a vehicle pretending to be another. I'll admit I've done this in the past, but wouldn't any more. As owner of the website, I've got a duty to encourage people to build safely & legally, but it's also just not worth it. It is illegal, you will get caught & the vehicle's logbook will be suspended. You might get away with it for a while, but the DVLA are tightening up their procedures & eventually MOT stations will refuse to test something that isn't what it says it is & once that happens they're obliged to inform DVLA, who'll send you a letter telling you the vehicle needs to be inspected. It'll be immediately obvious it's not a standard Reliant & they'll take away your V5C. Then you'll have to put it through the MSVA test to get it back on the road anyway.
To be honest, if the paperwork's not right, the trike should be re-registered. That's not nearly as difficult as it might sound though -there are several trikers here who've built vehicles & put them through the MSVA registration process, including Mr Old Newbie. Plenty of advice available here if you need to go that route. Not trying to discourage you in any way mate, just pointing out that if it's iffy, re-registering properly is the sensible way to go.  Wink
« Reply #6 on: November 07, 2013, 08:12:35 PM »
Some Reliants were registered new with body type- tricycle. That is why they became so popular with folk making trikes. They just transferred the numbers over to the new frame. We have even seen trikes with Ford running gear registered as 'Reliant' where the only Reliant part is the VIN plate.
« Reply #7 on: November 07, 2013, 09:51:14 PM »
Smiley :)put temp pipe in can too fuel
Have a wee look at
https://sites.google.com/site/fifersrelianthintsandtips/carb-stuff/carb-maintenance/floatbowl-bottom-seal-renewal
slug
welsh borders biker
« Reply #8 on: November 08, 2013, 03:03:28 AM »
 :)thanks fifer great info.. Smiley just what
I needed.. Smiley :)also thank you mankey monkey
for info , yes I agree 100%..also thanks old newbie
« Last Edit: November 08, 2013, 03:05:14 AM by slug » Logged
slug
welsh borders biker
« Reply #9 on: November 11, 2013, 12:59:32 PM »
 :)hi fifer and old newbie.. got small gland for carb bowl fuel pipe..
now not leaking all ok thanks.. cleaned carb and fuel pump.
got engine running quite well ,starts quickly.on key. quite a lot of white
smoke , what is this a sign of,, valve stem seals. head gasket,,???>
had another prob pin hole in front radiator, there are two on this trike..
small one on front , then larger one at rear piped together.. looks like on small
front radiator , they hit a speed bump and holed the bottom,,.
                cheers the slug,, Smiley Smiley Smiley
« Reply #10 on: November 11, 2013, 04:09:19 PM »
99% certain that it is nothing more than water vapour from condensation due to the time it has been lying  Smiley
« Reply #11 on: November 11, 2013, 04:15:52 PM »
If you download a form V888 from DVLA and send it off to them you will get all publically available info on whatever OWNED vehicle you ask about. This usually includes a copy of the V55/4 original reg sheet. As with many rods ( 2 axle rigid body on V5C ) it would surprise a lot of people.
slug
welsh borders biker
« Reply #12 on: November 11, 2013, 04:47:34 PM »
 :)hi kapri thanks,, have tel no of original builder
they are in Wrexham, they told me that because they
used over a certain percentage of original parts.. it
could be reg on original reg.. still looking into this..
 have not given up yet,, cheers.. :)thanks fifer yes
maybe mostly water vapour with engine being stood
so long ,, amazed engine runs at all,,
