April 24, 2026, 03:23:15 AM *
Author Topic: this week i am mostly being a builder  (Read 4795 times)
dobber
« on: November 01, 2013, 09:33:20 PM »
Yet another week n a bit taken away from fun projects. noticed a house i have at the side of my depot was dropping quite a bit of pointing over the last few weeks. realised the belly that's been there since i bought it some 8 or so years ago was getting bigger quicker than my belly is.
got in touch with the insurance company and would you believe it,,, a non starter.. took the subsidence bit off the policy last year..
 the through stone from the internal wall was a few inch shy of the outer skin.
        can i have it in 20 Min's?
dobber
« Reply #1 on: November 01, 2013, 09:35:35 PM »
got a mate of mine involved who is far more confident than me.. down to the hire shop for some tall acrows and strong boys to prop up the top bit
dobber
« Reply #2 on: November 01, 2013, 09:41:04 PM »
this is the second half which we dropped wednesday morning after rebuilding the patch to the right
dobber
« Reply #3 on: November 01, 2013, 09:45:32 PM »
had to course the stone that was reusable by size n stack it then clear out all the dross [rubble fill] from between the inner n outer skin.
found quite a bit of old repairs and changes. the earliest documents i have for the house are from 1735. big hand written  with wax stamps.
 used scaffold tube and clamps to lock the acrows together so if collapsed while pulling the stone out its less likely to knock the props out
« Last Edit: November 01, 2013, 09:49:39 PM by dobber » Logged
dobber
« Reply #4 on: November 01, 2013, 09:51:48 PM »
let the pointing go off a bit then trimmed it up. unfortunatly not got the time at the mo to do it as nice as it could be.
dobber
« Reply #5 on: November 01, 2013, 09:53:48 PM »
used a trailer chassis with pallets on to store the stone  we were working with so not bending all the time
« Last Edit: November 01, 2013, 10:05:04 PM by dobber » Logged
dobber
« Reply #6 on: November 01, 2013, 09:57:05 PM »
drilled into the inner wall gently to put in some brick ties, drilled the hole, blow it out with the compressor then bonded in the tie with chemi fix.
the reason it gave in the first place was not enough through stones.
dobber
« Reply #7 on: November 01, 2013, 10:02:13 PM »
got rained off today, set 5 days aside to complete but gonna run into 7 by the look of it.
« Reply #8 on: November 01, 2013, 10:51:48 PM »
Hi Dobber. Are there acro's on the inner skin with a pin between or are they on one side only?
dobber
« Reply #9 on: November 01, 2013, 11:00:17 PM »
hey up Andy.. they are just under the outer course of stone. we followed the  outside of the belly then drilled into the original lime morter of the nearest  big stone then hammer the strong boy in.. once its in to its limit we hook the acrow in and pressure it up.. been using them on the pub im converting to a house so got a bit more confidence in it now.
« Last Edit: November 04, 2013, 07:42:25 PM by dobber » Logged
« Reply #10 on: November 02, 2013, 10:45:19 AM »
Nice job!
http://www.choppit.co.uk
« Reply #11 on: November 02, 2013, 08:21:44 PM »
Looks like you pretty much know whay you are doing!  Big job though.
slug
welsh borders biker
« Reply #12 on: November 04, 2013, 05:20:52 PM »
 Smiley very professional job.. going about it the right way..
real good,  Smiley Smiley Smiley Smiley Smiley Smiley
dobber
« Reply #13 on: November 06, 2013, 09:40:38 PM »
thanks folk...
had to get some more stone to replace the damaged bits. luckily i had some up at a pub I'm turning into a house. different type I'm told came from near ilkly which is a lot harder than the local sand stone. as we build up the courses we back fill it with the rubble [dross] that came out mixed in with cement. this makes for a very strong wall.
« Last Edit: November 06, 2013, 09:42:54 PM by dobber » Logged
dobber
« Reply #14 on: November 06, 2013, 09:46:33 PM »
my mate Simon who gave me the confidence to do the job our selves..    cement smoothed off ready for the next course
