December 24, 2025, 08:52:04 AM *
Pages: 1 [2]
Author Topic: Edwardian Speedster  (Read 12419 times)
« Reply #15 on: September 22, 2013, 07:54:23 PM »
« Reply #16 on: September 23, 2013, 07:49:07 AM »
http://www.ebay.co.uk/itm/Ford-Model-Y-rolling-chassis-Hot-Rat-Rod-special-Heritage-Stock-Car-1932-7-/161111347347?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2582fc1093
good start for a special..
« Reply #17 on: September 23, 2013, 08:24:56 AM »
Land Rover based Brooklands special... as far as I can remember all LR running gear but with a sherpa front axle..
« Reply #18 on: September 23, 2013, 08:26:04 AM »
no I lie.. home made beam front and sherpa rear....
« Reply #19 on: September 23, 2013, 08:33:59 AM »
Yep. This is at least the second time that this has been listed. Son lives fairly close so will try get him to check it out. Don't think an old tax disc would be enough to keep the registration as there is no mention of visible chassis number. The wheels and axles etc. might be worth saving.
« Reply #20 on: September 23, 2013, 08:48:27 AM »
Land Rover actually made a few 2wd vehicles but I don't think that was one of them Cheesy
Looks like the original swivel pin balls have been bolted onto a straight flanged tube. A simple conversion.
The 109 would also make quite a good base for a 30s Bentley style vehicle.
« Last Edit: September 23, 2013, 09:11:37 AM by Old Newbie » Logged
« Reply #21 on: September 23, 2013, 09:10:25 PM »
Chassis number on frame
At the time of manufacture/assembly all vehicles were marked on the chassis frame or later body, with the original engine's number, and locating this can involve a certain amount of very careful examination. Please remember that this is the 'original engine's number' as factory fitted. Upright models, including Model Y through 103E all had the number stamped into the flat horizontal surface of the main right hand chassis side rail (left side for lhd), just ahead or beside the cross member rivets of the diagonal brace, just to the rear of the steering box. The distinctive leaning characters are sometimes preceded by a star, then Y for 8hp, C for 10hp, then the numerals, sometimes finishing with a star. This can be read by standing beside the vehicle and once the bonnet is lifted, looking down to the chassis rail.
100E and 107E models usually had the number stamped around the plate, which is held in place by three nuts, which forms the suspension unit upper mounting on the driver's side in the engine bay.
« Reply #22 on: September 23, 2013, 09:30:28 PM »
Thanks Chewie. Will ask, but with the description given, I'm not convinced that any number left will be legible.
Update- Checked with vendor and the chassis number has rusted away.
« Last Edit: September 24, 2013, 07:38:16 AM by Old Newbie » Logged
« Reply #23 on: September 24, 2013, 08:09:10 AM »
That really has the look of a LandRover about it doesn't it. Like it.
Pages: 1 [2]
