March 16, 2026, 03:56:59 PM *
Author Topic: DeScale water cooling sytem  (Read 1635 times)
saex69
« on: September 22, 2013, 12:41:50 AM »
Don't know if any one has done a thread on descale the cooling system on a engine before, it's a must on the little Reliants and depends on what the water is like were you live. Now as i had my 850 engine out for a clean up i thought i would check every thing oil seal's plugs the works as i took the head the piston still std and clean :)then was checking water system i noticed the 2 rear holes were compleatly blocked Cry with lime scale so had a bit poke around as you do and got some out so thought bugger this out came the air line and cave it a good o'l blast yerp i was cover'd from head to toe in white powder Cheesy, it took an other 15mins before it was cleaned out so next was the fitting of the water pump then i pored hot water down the tube not filling it to the top i had to leave room to pore some descale fluid in leave for about 5 to 10 mins or until fizzing stopped then pore out making shore not to get it in the barrels or the push rod tubs now its all nice and clean just like new. Grin
