March 16, 2026, 05:35:04 PM *
Author Topic: Diff caseing studs  (Read 7746 times)
« on: September 20, 2013, 08:39:35 AM »
Can any one tell me where I can get new diff casing studs and domed stainless nuts from,
any help would be appreciated
Thanks
Merv
« Reply #1 on: September 20, 2013, 10:31:45 PM »
Well
can any one help, if not how do I put my diff back together
steven brock
« Reply #2 on: September 21, 2013, 08:16:09 AM »
Think they 5/16 unf maybe good ole eBay.. from memory I think to replace them seemed expensive for dome nuts
« Reply #3 on: September 21, 2013, 08:42:58 AM »
Thanks Steve
Sounds like the studs are hard to come by, if I had known I would not have thrown the studs out when I stripped the axle, doh.
« Reply #4 on: September 21, 2013, 08:52:15 AM »
How bad are the old studs?
Without pulling the studs from my axle I'm not sure but they may be unf at the nut end but I would expect them to be unc in the casing.
Better check this.
Various lengths are available via ebay
« Reply #5 on: September 21, 2013, 08:59:14 AM »
OK have removed a stud.
Yep 5/16" unf - unc x 2" long. Thread lengths each end approx. 5/8" (16mm)
You should be able to find some manifold studs that size.
Hope that helps.
« Reply #6 on: September 21, 2013, 09:01:55 AM »
Hi Old's
The thing is I haven't got them I threw them away when I stripped the axle, my thinking was to buy new.
Been looking on eBay cant seem to find any maybe using the wrong terminology or wording
« Reply #7 on: September 21, 2013, 09:04:52 AM »
Thanks Old's
Would the reliant exhaust studs be the same?
« Reply #8 on: September 21, 2013, 09:10:01 AM »
Think they are shorter, may be OK. but these should do
http://www.ebay.co.uk/itm/Mini-Thermostat-Manifold-Stud-HIF-SU-Austin-Morris-BMC-Rover-5-16-UNF-UNC-/130974317344?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e7ead7b20
« Reply #9 on: September 21, 2013, 09:13:32 AM »
Would these be long enough Merv.
http://www.ebay.co.uk/itm/5-16-x-1-11-16-UNC-UNF-Manifold-Studs-With-Brass-Nut-MGB-Exhaust-Flange-/350746790627?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item51aa234ae3
« Reply #10 on: September 21, 2013, 09:20:44 AM »
Hi hunter
Thanks, I don't know at the moment, hey Old's you still reading sorry to be a nuisance but the link hunter sent through would they suit ?
« Reply #11 on: September 21, 2013, 09:24:03 AM »
Not really. To short and are for screwing into a cast iron manifold, the unc section is less than 10mm long.
« Last Edit: September 21, 2013, 09:48:39 AM by Old Newbie » Logged
« Reply #12 on: September 21, 2013, 09:38:46 AM »
http://www.ebay.co.uk/itm/THERMOSTAT-HOUSE-STUD-5-16-UNC-FOR-A-SERIES-MINI-AUSTIN-METRO-MG-A-A-TURBO-1275/280650196278?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D17234%26meid%3D1440607581003840289%26pid%3D100005%26prg%3D8045%26rk%3D2%26rkt%3D4%26sd%3D270815879318%26
These should do it.
« Reply #13 on: September 21, 2013, 09:54:02 AM »
Thanks you two, you both have been a great help
« Reply #14 on: September 21, 2013, 10:12:52 AM »
S'OK.  Smiley
Just check that the unc section is at least 14mm otherwise the risk of pulling the ally threads is a lot higher.
