April 30, 2026, 06:09:48 AM *
Pages: 1 ... 8 9 [10] 11
Author Topic: NEW PROJECT !!!!!!!!!!!!!!!!!  (Read 85536 times)
« Reply #135 on: November 03, 2013, 09:34:31 AM »
Somehow I doubt that'll slow you down mate.
I was thinking the same  Smiley
« Reply #136 on: November 03, 2013, 08:50:55 PM »
Well only temporarily at least!
« Reply #137 on: November 07, 2013, 11:16:59 PM »
work has started on the dodge , cant start doing to much to the gmc untill i know if the builder is going to start on the garage ,, cant have a big dead truck in the way .
so yesterday i fitted two new front tyres  that i bought at the swap meet brand new £15 each but i may end up with differant wheels eventually and today i fitted a fresh starter motor ,fiddleled ,, with the gear linkage and greased the water pump bearings etc,,etc ,then had a ride down the dirt track ,,
« Reply #138 on: December 06, 2013, 10:38:13 PM »
collected the ,new old stock, rear tyres for the GMC .
http://i468.photobucket.com/albums/rr41/spanners1964/newtyres001_zps33519b5f.jpg
http://i468.photobucket.com/albums/rr41/spanners1964/newtyres002_zpsc60d7593.jpg
http://i468.photobucket.com/albums/rr41/spanners1964/newtyres003_zpsb2e53f20.jpg
2 have been mounted but not used the other3 havnt .
goose
« Reply #139 on: December 07, 2013, 04:30:55 PM »
slowly getting there mike , like the old split rims , b****r to get back together though  once you have split them , either that or I was doing it wrong , probably the latter Grin Grin
« Reply #140 on: December 07, 2013, 05:08:52 PM »
Probably using the wrong size hammer  Cheesy And no they wont fit your trike  Grin
« Reply #141 on: December 07, 2013, 05:10:59 PM »
its not the hammer its how you hit it  Wink Wink
oldmetalhead82
« Reply #142 on: December 07, 2013, 11:49:32 PM »
Hope you've got a cage to put them split rims in to inflate the tyres Mike!
« Reply #143 on: December 08, 2013, 12:03:14 AM »
no cage, Shocked Shocked Shocked going to have to be ,old school,, laced with a chian round the tyre and through the hand holes  Wink
« Reply #144 on: December 08, 2013, 06:16:19 PM »
split rim wheels, glad i don't have to do them anymore, and we did'nt have a cage to use, and they had 100lb pressure in them!!!!
« Reply #145 on: December 09, 2013, 09:24:08 PM »
been working on the dodge today from 9am till after dark  Shocked  not a bad day shift for me as thing have been lately,
its been puzzling me why yanks and electrics dont mix  Undecided i found out today that yanks are basically ,,THICK,,,,
the dodge runs reasonably well ,,engine wise,,, but the dynamo bearings were a bit grumbley,, and the ign light didnt work on the dash,,
well the light wouldn,t work because it had no bulb in it  Roll Eyes Roll Eyes and the wiring was naff..
i sorted that , then set about testing the dynamo and regulator box with the engine running and everything connected up all to no avail or poor output results ...
so i idependently wired the dynamo and the control box  and hay,,ho,, when i excited the dynamo again i got a weak output ,,checked the regulator box and all was fine with that  but still weak output from the dynamo  Huh Huh
i eventually did an old school cheat ,accross the dynamo terminals and got 9.5 volts at high rpm
so i removed  the dynamo ,cleaned and inspected the scruffy,,battered ID plate and hay ho,, thick yanks had fitted a 6volt dynamo on a 12 volt system  Roll Eyes Roll Eyes Roll Eyes
its either that or the truck has been converted from 6 volt to 12 volt and only half a job done
but one things for shure ,,, yanks and auto electrics dont mix,,,,,,,, and the wire quality can best be described as ,,NAFF,,
so as a last and maybe temporey measure i,v converted it to an alternator and by 5pm she was up and running again..
« Reply #146 on: December 09, 2013, 10:48:11 PM »
Can't beat ol' school know-how Mike. Well done.
« Reply #147 on: December 09, 2013, 11:01:26 PM »
just working my way through it , getting things into better working order , got it for sale but  not bothered about selling it as its growing on me
it,ll make a good shopping daily runner with that touch of character,,,
dosn,t look like it,ll be to bad on the  ,motion lotion, either  6cyl flat head engine is as sweet as a nut and i havn,t touched the carb of ignition as yet ,,,
« Reply #148 on: December 12, 2013, 10:57:16 PM »
must remember to take camera up the garage in the next day or so because i know you lot like pictures  Cheesy Cheesy
and some of this lot will be going into ,hibernation,, in the next couple of weeks to make room for the concrete truck coming ,,
« Reply #149 on: December 13, 2013, 05:20:09 AM »
Is that for the workshop floor, or have you bought another truck? Cheesy
Found this and thought of you  Cheesy
http://www.youtube.com/watch?v=8M1o2rpO_JY
« Last Edit: December 13, 2013, 11:39:33 AM by Old Newbie » Logged
