March 14, 2026, 04:54:29 PM
Trike Tech
the magic formula
Topic: the magic formula (Read 1704 times)
bandit5050
the magic formula
July 29, 2013, 07:12:24 PM »
got a gsxf750 trike with standard cog on front with chain going to a beval box onto the propshaft of a reliant axle? is there a way of working out what wheel and tyre size to use.also what cog size on the beval box?.......think that makes sence
.cheers ady
Re: the magic formula
July 29, 2013, 08:55:33 PM »
Need a lot more information than you have supplied but the formula is
MPH = RPM x ERWR / GR x 168
ERWR is the Effective Rear Wheel Radius, that is, the wheel radius + height of the tyre
GR is the Gear ratio and that`s the total gear reduction. Most bikes have a secondary reduction to the input shaft as well as the primary + (in your case) the bevel box reduction + the axle reduction.
so working the other way, ERWR (that`s wheel and tyre size) = MPH x GR x 168 / RPM
I forgot to add that you really want your bevel box output 1:1 with the engine output shaft cos then you can eliminate it from the equation.
Last Edit: July 29, 2013, 09:08:44 PM by tbone
