March 19, 2026, 01:46:19 PM *
Pages: 1 ... 13 14 [15] 16 17 ... 19
Author Topic: Bleedin' radiator! HELP/discuss pls......  (Read 97002 times)
« Reply #210 on: August 05, 2013, 08:52:07 PM »
Think they should be 4 thou. the reconditioner told me about that,and said he would make sure that they were ok. They look ok to me on inspection.
« Reply #211 on: August 05, 2013, 08:52:34 PM »
were the ring gapped when the engine was rebuilt. could be when they get hot and expand thats caused this
« Reply #212 on: August 05, 2013, 08:54:57 PM »
dont know,he rebuilt the bottom end and pistons.All the pistons,when checked at top of bore have roughly the same amount of side play movement (very small)
« Last Edit: August 05, 2013, 08:56:48 PM by ROD » Logged
« Reply #213 on: August 05, 2013, 08:57:34 PM »
i expected to see ,cross hatching,  honing marks on the bores  Roll Eyes Roll Eyes but the blob marks dont look good  could be hard bits in the liner,== poor quality  Shocked
« Reply #214 on: August 05, 2013, 08:58:20 PM »
The cross hatching is there in all 4 bores,as I say,couldnt get a good pic.
 My plan is to take it back to themm to see what they say. Im very reluctant though,as they may not tell me if its their workmanship at fault! I will at least get the liner and piston replaced. Although talk at the moment here is to go to another reconditioner...Im between a rock and a hard place!
 I went to them as they are 2 older guys in a old established firm,so I thought they would know their stuff! Ive since heard that they have had probs with at least one other trade customer as well.
 I want it to be right for whoever buys it.
« Last Edit: August 05, 2013, 09:06:17 PM by ROD » Logged
« Reply #215 on: August 05, 2013, 09:06:18 PM »
get another engine. this one has more than piston and liner issues wrong with it
« Reply #216 on: August 05, 2013, 09:07:49 PM »
My sentiments entirely mate! Im into this one for about a grand,so its a hard pill to swallow!I really did think I was doing the best thing by having it reconditioned,so that it would last a long time.I'll try to source one........
« Last Edit: August 05, 2013, 09:10:08 PM by ROD » Logged
« Reply #217 on: August 05, 2013, 09:18:21 PM »
Sack that! You paid em to make it good. Get you money back, its not pocket change.
« Reply #218 on: August 05, 2013, 09:26:12 PM »
I'll go down there on Weds with the engine ,and the invoice,but TBH I dont hold much hope!
« Reply #219 on: August 05, 2013, 10:24:57 PM »
Well, you do have some rights here. Its not unreasonable to expect it to do what they said it would. Who sourced the parts they fitted?
« Reply #220 on: August 05, 2013, 11:22:55 PM »
They did
« Reply #221 on: August 06, 2013, 06:54:13 AM »
Only two things that I can think of to make rough radial marks with spotting would be a rusty liner that someone has tried  to clean up with emery when honing didn't do it, or possibly ring chatter, but chatter wouldn't explain the spots. Difficult to say without seeing them.
The apparent running richer on 3 & 4 could simply be down to slightly worn valve guides.
The fact that you are pulling out clumps of liner sealant suggests the rebuild was not done with great care. A lump of sealant that got loose could  block a waterway in the head. Might be worthwhile blowing out the waterways with an airline.
Good luck mate.
« Reply #222 on: August 06, 2013, 07:18:11 AM »
Full refund, if prompt you wont chase them for your additional losses
« Reply #223 on: August 06, 2013, 07:25:29 AM »
May be pushing you luck on that one. it may need a full engineers report more money. just see what they say This problem started over a year ago and it been cooked at least twice. lets hope they dont look at forums
« Reply #224 on: August 06, 2013, 07:35:22 AM »
Rod is there any letters stamped on the top of the pistons
