March 13, 2026, 08:21:03 PM *
Author Topic: Exhausted (nearly)  (Read 5168 times)
« on: July 10, 2013, 09:50:14 PM »
Ive don e some work on the exhaust routing today. All has gone well, i do however face one little issue. I am running the front pipe above the frame centrally near the prop shaft. That works well but it crosses and recrosses the frame above the frame. I would like to support it at those points but not transfer the heat onto the frame. Any suggestions?
« Reply #1 on: July 10, 2013, 09:50:40 PM »
« Reply #2 on: July 10, 2013, 09:55:12 PM »
« Reply #3 on: July 10, 2013, 10:02:47 PM »
tab brackets n, mini exhaust ,bobbins, Wink
« Reply #4 on: July 10, 2013, 10:08:10 PM »
like these Mike?
http://www.ebay.co.uk/itm/CLASSIC-MINI-REAR-EXHAUST-MOUNTING-PACK-of-4-COTTON-REEL-BOBBIN-TYPE-/121134402639?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c342c4c4f
« Reply #5 on: July 10, 2013, 10:11:27 PM »
That's them Andy.
I used them on my truck but the rear ones have started to split. Mr Kapri told me they shouldn't be used to suspend an exhaust from as I've done, but should sit under the pipe so it's weight is on them, rather than hanging off them. The mounting studs are usually Imperial by the way, not Metric, (had a mate try to force a Metric nut on one a while ago).
« Reply #6 on: July 10, 2013, 10:20:23 PM »
thats them when in there original position on a classic mini they were/are mounted with the studs horizontal and used to last quite well but they last almost for ever when mounted in commpression ,
« Reply #7 on: July 10, 2013, 10:22:51 PM »
Ordered, coming on Friday. Its starting to feel like it will be finished sooner rather than later Smiley I have great plans for the leather trim Smiley
« Reply #8 on: July 11, 2013, 06:18:11 PM »
Ooh, sounds interesting!
« Reply #9 on: July 11, 2013, 07:14:52 PM »
I have just bolted mine solidly to the frame ,as the engine is ridgedly mounted it shouldn't need to move.
or is your engine rubber mounted,maybe i'm jumping the gun
« Reply #10 on: July 11, 2013, 07:54:55 PM »
youde be suprised how much an exhaust moves as i expands
« Reply #11 on: July 11, 2013, 08:00:43 PM »
I've rigid mounted exhausts in the past without any problems, but would still rubber mount them I think. Even though the motor's solid mounted, there are still vibrations & stresses transmitted to the pipes. I'd be concerned about stress fractures.
« Reply #12 on: July 11, 2013, 10:44:18 PM »
I hadn't thought about the stress fractures part of it, but yes, vibration, oscillations and mostly heat. I want to keep the heat from transferring directly to the frame.
« Reply #13 on: July 11, 2013, 10:45:54 PM »
I hope so, we are going to make some nice curved tunnel panels with all that leather, and finish the front edge to the frame with stainless mesh. May mock one up this weekend to get the look of it.
