April 23, 2026, 06:40:13 PM *
Author Topic: Lucas 45D4 distributor  (Read 3682 times)
« on: July 06, 2013, 08:01:54 AM »
Having a senior moment here. Tongue
The cam on my distributor is not secured and can move upwards to the point that the rotor is hitting the four electrodes. I can remember that the 23D has a screw down the centre but for the life of me can't remember what is supposed to secure it on the 45D. Have some vague recollection of either a c clip or a plastic collar. Undecided
Either way, something is missing.
« Reply #1 on: July 06, 2013, 08:46:29 AM »
OK Took off the distributor, gave it a good shaking and think I've found it! God only knows how it ended up down in the distributor body Huh
Now only thing is to work out which way up it's supposed to fit.
« Reply #2 on: July 06, 2013, 09:26:06 AM »
that looks like the insulating washer of the points  Undecided Undecided Undecided not a retaining clip
« Reply #3 on: July 06, 2013, 05:17:15 PM »
That's what I thought when it fell out but it's not the same as the one on the points. It was a nice tight fit on the spindle that comes up through the centre of the cam and when pressed in, clicked into place allowing 2mm or so of vertical movement.
trikerpete
« Reply #4 on: July 07, 2013, 03:39:13 PM »
Sounds like youve sorted it ON. So tell us, which way up did it fit? Smiley
« Reply #5 on: July 07, 2013, 03:57:50 PM »
same way as its showing in his pic above ,,iv just had a look at my spare one down the garage ,,
« Reply #6 on: July 07, 2013, 04:09:28 PM »
Flange first. If you fit it the other way there is still a lot of movement. Never pulled one of these apart so not sure how it's supposed to be assembled. Without the collar the cam was free to move up, held down only by the cap.
For all I know the collar should be the other way up with a spring under it. But it works so that will do.
« Reply #7 on: July 07, 2013, 04:13:11 PM »
Hey I got it right. Now how the hell did it get down in the body  Huh
