March 13, 2026, 06:40:28 PM *
Author Topic: Brake line fixing  (Read 5745 times)
« on: July 05, 2013, 07:46:04 PM »
I am proposing to use this method for fixing the brake pipes and handbrake cable. A hole is drilled and tapped, then the pipe is secured using a stainless p-clip with rubber liner and a stainless screw. Is this acceptable for the msva?
« Reply #1 on: July 05, 2013, 07:47:08 PM »
« Reply #2 on: July 05, 2013, 08:13:13 PM »
Should be, provided the pipe can't move in the clip & the mounting hole doesn't seriously weaken the frame tube, (should be fine on thick walled ERW tube, but maybe keep away from high stress areas if you can).
WAYNE999
« Reply #3 on: July 05, 2013, 08:40:14 PM »
More than fine mate,my hand brake cables are held up with cable ties and the brake pipes with "double loop" cable ties so p-clips fitted properly will be fine
« Reply #4 on: July 05, 2013, 08:48:44 PM »
3mm CDs so that's ok then. Point taken about stress points Smiley
« Reply #5 on: July 05, 2013, 08:50:52 PM »
Thanks Wayne. That is very reassuring. The copper will be nickel plated (replica chrome) so I want the fixings to set that off Smiley was worried what was needed.
« Reply #6 on: July 05, 2013, 08:51:47 PM »
I've did the same thing Andy so hopefully should be ok and looks neat
« Reply #7 on: July 05, 2013, 08:55:39 PM »
Thanks  Scannerzer. Yes, I saw some P clips on your build (I think )
« Reply #8 on: July 06, 2013, 06:57:12 AM »
For the brake pipes, because I didn't want the hassle of drilling, I used zip ties with short (5mm) lengths of 6mm plastic tube to form the stand offs.
MSVA inspector was more than happy about this.
« Reply #9 on: July 06, 2013, 08:58:35 PM »
That's equally tidy Dave -& ingenious.
WAYNE999
« Reply #10 on: July 07, 2013, 08:10:14 AM »
These are what I used and the VOSA man was happy
http://www.cabletiesonline.co.uk/cable-ties-other/double-loop-style-cable-ties-200-x-4-8mm/prod_1118.html
