April 24, 2026, 01:16:34 AM *
Pages: 1 [2]
Author Topic: fork leg spacers  (Read 11097 times)
little kwaka
« Reply #15 on: June 16, 2013, 09:49:06 PM »
i started the build on the 31st of may , it was stood on its wheels in 4 days , cracking on with it , and when this is built i have a kawasaki gt550 to trike , best regards tony
http://i888.photobucket.com/albums/ac90/skyeices/IMG_2429_zpsd130d3f0.jpg
fork leg spacers
http://i888.photobucket.com/albums/ac90/skyeices/IMG_2436_zps31e9dd7d.jpg
fork leg spacers
http://i888.photobucket.com/albums/ac90/skyeices/IMG_2457_zpsfc751816.jpg
fork leg spacers
http://i888.photobucket.com/albums/ac90/skyeices/IMG_2467_zpse59ec45d.jpg
fork leg spacers
http://i888.photobucket.com/albums/ac90/skyeices/IMG_2473_zps4e1c3925.jpg
fork leg spacers
http://i888.photobucket.com/albums/ac90/skyeices/IMG_2472_zps98c266cb.jpg
fork leg spacers
« Reply #16 on: June 16, 2013, 10:12:56 PM »
OK here we go,
The full length of the forks is 31.1/2in,  They are single disc.
Wheel spindle dia 12mm.
The right bottom spindle hole has a steel sleeve in it to reduce hole size for spindle.
if removed the hole would be 24mm.So bigger spindle no problem.
The other leg has a 12mm threaded hole,This could be bored out and re-tapped to around 18mm.
The wheel size is 2.15x17.You could use the 600 wheel if the yoke spacing would allow you.
« Reply #17 on: June 16, 2013, 10:31:11 PM »
love the tank Kwaka ,it will be a nice trike and very fast work well done
little kwaka
« Reply #18 on: June 16, 2013, 10:52:54 PM »
thanks scannerzer,,, i like old school,,, maybe because im 50yrs old and allways had that type of thing,,,,,, everything old ends up going full circle and back in fasion at some point,,,
cheers
tony,,,,, isle of skye,,
« Reply #19 on: June 17, 2013, 08:14:06 AM »
Fast work indeed.
I wonder how many prism tanks from the 70s are out there. Seen a few recently Smiley
« Reply #20 on: June 17, 2013, 11:04:38 AM »
one hung up in my garage ,,
little kwaka
« Reply #21 on: June 24, 2013, 05:39:14 AM »
Fast work indeed.
i bought the coffin tank initially for my next build gt550 kwaka but it was too short,,,,, need another for my gt550 but might have to have one made special,
cheers
tony
trikerpete
« Reply #22 on: June 25, 2013, 09:01:44 PM »
Youve been busy Tony. Im still sourcing parts for next build Smiley
little kwaka
« Reply #23 on: June 27, 2013, 11:38:16 AM »
what you needing pete mate,,,  Wink
trikerpete
« Reply #24 on: June 27, 2013, 06:05:40 PM »
mini chrome speedo, l/h & r/h switchgear for 7/8th bars, headlight, 120/70/17 front tyre, bag of tenners Smiley
little kwaka
« Reply #25 on: June 27, 2013, 08:17:17 PM »
hi mate,, i can help you with switches, in a fashion i can give you some off a quad, there 7/8th but no indicator switch, but theres the kill switch, start button and lights on the one cluster,,, im needing some 1" switches and a mini speedo also,,,,, and a pair of regal half shafts and flanges,,,
best regards
tony,,,,,, skye
trikerpete
« Reply #26 on: June 30, 2013, 09:44:16 PM »
thanks for offer tony but would like matching set with indicators etc etc. good luck in sourcing halfshafts. thinking about it contact bruce at bb customs down in dorset on mainland, tell him i sent you  Smiley
little kwaka
« Reply #27 on: July 01, 2013, 11:08:29 PM »
thanks very much pete i will follow your suggestion up,,, these regal ones are hard to find..... when you very first made contact with me when i had my reliant trike unleaded abandoned project on ebay for sale £300 about 2 years ago that was a regal axle i let go with that,,,, it went to orkney isles,,,,,
cheers mate
tony,,,
« Reply #28 on: July 02, 2013, 06:34:31 AM »
These days a abandoned project is probably the cheapest way of getting a good early axle.
Pages: 1 [2]
