April 24, 2026, 12:38:59 PM
General Tech
brake fluid cleaner?
Topic: brake fluid cleaner? (Read 2496 times)
June 04, 2013, 04:19:23 PM »
Whilst dealing with my brake problem.Ive noticed that I have brake fluid on my frame
,presumably where it has leaked out of the cap,and blown rearward over the frame. Quite bad,blistered etc and paint falling off. I seem to recall there is some sort of household cleaner(neat bleach?) that I can wash the area with and it will also neutralize the fluid ,to allow me to repaint after rubbing down . Has anyone any ideas?
Re: brake fluid cleaner?
June 04, 2013, 04:44:42 PM »
I've only ever used warm water and washing-up liquid. Any paint that has softened will probably need scraping off.
cunningplan
June 04, 2013, 06:10:47 PM »
As above, just give it s good wash with soapy water.
If you every need to use brake fluid for bleeding brakes or clutch have some water on stand by, if you spill any just rinse it off straight away.
Last Edit: June 04, 2013, 06:13:03 PM by cunningplan
June 08, 2013, 10:49:14 AM »
i lost a lot off primer from my minx when brake pipe sprung out an sprayed fluid everywhere, not a lot you can do to save anything.
https://youtube.com/user/poprodder
https://www.facebook.com/chrisdralph
I'm on Instagram as @notafoolsvan. Install the app to follow my photos and videos.
https://www.instagram.com/invites/contact/?i=1d8fqu34c7rb6&utm_content=1fsuk8k
