March 18, 2026, 12:15:48 PM *
Pages: 1 ... 12 13 [14] 15 16
Author Topic: Girder Forks.  (Read 77876 times)
« Reply #195 on: November 24, 2013, 12:03:56 AM »
Probably were Mr M, as I can't remember where they came from!, but they might interest Dave re. Headlamp position etc.so......................... Morrag
« Reply #196 on: November 24, 2013, 08:30:17 AM »
Yep, have seen before but thanks morrag. The Indian leafer forks are lovely and lend themselves well to trikes as you can change the short bottom links so instead of being trailing they are leading, pushing the axle line forwards, reducing the trail. The leaf spring needs changing, as this is normally being pulled down and is now being pushed up. Thought about doing leafer forks instead of girders, but because of the bottom links, they have the same problems as springers when used in a trike. Maybe with wide enough pivots  Undecided.. Undecided.. Undecided.. Smiley.. Grin
Perhaps next year   Cheesy
« Last Edit: November 24, 2013, 08:52:50 AM by Old Newbie » Logged
« Reply #197 on: November 25, 2013, 03:29:19 PM »
Incorporated the brake splitter mounting into the lower shock /horn mount. Will need longer hose from mc to splitter and already have the shorter ones in stock to fit between splitter and calipers.
Assembled as far as I need, to check everything is ok prior to stripping down and painting. Would like to find a more appropriate mudguard, but this will do until the right one comes along
Still not sure about the mounting of the front indicators. No matter where I put them the look totally out of place Angry  Thinking of converting the sidelights and fitting small high intensity led sidelights into the pickup bed tubes that at present have the white hand holds fitted into.  It's either that or mount the indicators to the handlebars Undecided
« Reply #198 on: November 25, 2013, 06:18:26 PM »
Totally changes the look of the trike doesn't it. Does the suspension work O.K?
« Reply #199 on: November 25, 2013, 07:40:29 PM »
Either side of the headlight?  Reckon that would look good.
« Reply #200 on: November 25, 2013, 07:49:44 PM »
As I have already said Dave,those girders are a cracking piece of motorcycle engineering, but personally, I prefer the look with its original forks on your trike, but it's purely my taste, Morrag
« Reply #201 on: November 25, 2013, 09:20:43 PM »
Suspension seems to work fine. Took it down the road (no front brakes or mudguard fitted), didn't go far or at any speed but it didn't bounce around or bottom out, the steering was also a lot lighter.
Tried that  Undecided recon the question of indicators is now irrelevant
Funny you should say that.
 Have just spent 3 hours doing absolutely nothing but look at it. Conclusion is I'm not happy with the overall result  Angry
I can remember a while ago saying that I wasn't sure. Now I am. So for now it looks like I will be reverting back to the teles until I come up with something better.
 Oh well it was fun trying Smiley
 I will keep them just in case I decide on a new build that will suit them more, such as the steampunk trike my daughter has been bugging me about.
« Last Edit: November 25, 2013, 11:21:10 PM by Old Newbie » Logged
« Reply #202 on: November 26, 2013, 12:20:25 AM »
What a shame. They look nice, but are not as 'chunky' as the rest of the machine. Are you sure the look wont improve with painting?
« Reply #203 on: November 26, 2013, 08:06:13 AM »
Possibly but I doubt it. I still like the girders but when you stand back and look at the whole trike, it somehow doesn't work for me. I think the problem lies in the fact that the rest of the trike is quite compact, but there is a huge space between the front down tubes and the forks.  If the rad was fitted in front of the down tubes as originally designed, it would partially fill this area and also visually open up space around the engine. When for expediency sake I fitted the teles, I felt that it would look better with the rad fitted inside the frame.
I'm not upset about this at all.  It's been fun, I now know that I can and they may still get used  Smiley
« Last Edit: November 26, 2013, 10:16:08 AM by Old Newbie » Logged
« Reply #204 on: November 26, 2013, 01:30:53 PM »
Directly comparing the two pics - yes, the original is better!  Oh well, nothing ventured....
« Reply #205 on: November 26, 2013, 02:36:05 PM »
Well, no doubt, like myself so many times in the past, they will go on the "comein'andy" stockpile Dave, and if not, how about as a feature over the fireplace!! Wink Wink Wink Wink Wink Wink Wink Wink.....and the second pic, that's definitely the package.........Morrag
« Reply #206 on: November 26, 2013, 06:22:35 PM »
Brave decision Dave -most of us would've made do with them after all that work. But if you're not happy with them, they'll never be right. I think painting them black would've helped a lot, but as the slogan says: "I built it to please me, not you".
stumpy
« Reply #207 on: November 26, 2013, 06:50:41 PM »
yeah paint them with chunky paint  lol i think they look well on there but tis your baby
« Reply #208 on: November 26, 2013, 08:25:06 PM »
I recon if you dropped the bars down, and moved the headlight down in front of the girders / above the mudguard you would get beck to a sleek look. As many have said though, we build for ourselves not others. Whatever you decide, "go with throttle up"
steven brock
« Reply #209 on: November 26, 2013, 08:42:51 PM »
Air scoop at front may fill that gap.. Both look stunning to me
