November 04, 2025, 09:44:32 PM *
Author Topic: xl 125 lights not working  (Read 6611 times)
kinkytriker
« on: May 19, 2013, 08:16:24 AM »
hi my xl 125 varedero lights have packed up,
checked the bulbs the fuse and cant see any probs with wiring,
could it be the ignition, as the lights come on when the ignition is turned on Huh
« Reply #1 on: May 19, 2013, 09:54:11 AM »
i've had a similar problem recently ,the switchs had a light film of corrosion from the winter lay up. a few squrts of switch cleaner and flick the switches back and forth sorted it out,worth a try
kinkytriker
« Reply #2 on: May 19, 2013, 10:21:12 AM »
cheers will try that, it has been sat out side for a few days in the rain Roll Eyes
kinkytriker
« Reply #3 on: May 19, 2013, 10:38:25 AM »
cleaned the switch but still not working Sad
« Reply #4 on: May 19, 2013, 05:22:47 PM »
Does the horn still work?
Some Hondas seem to use a common earth for all the lights and often the horn as well.
Check the earth lead and connection.
kinkytriker
« Reply #5 on: May 20, 2013, 05:28:10 AM »
yes horn, back light, break light and indicators are all still working Roll Eyes
could it be the ignition as the lights come on when i turn it on?
« Last Edit: May 20, 2013, 06:40:57 AM by kinkytriker » Logged
« Reply #6 on: May 20, 2013, 07:03:22 AM »
So it's just the headlamp that's not working then and probably instrument lights.
When you say
do you mean that the headlight is still working but only if you turn on the ignition or that they should come on with the ignition but now don't,
« Last Edit: May 20, 2013, 07:10:56 AM by Old Newbie » Logged
kinkytriker
« Reply #7 on: May 20, 2013, 07:12:14 AM »
the lights are meant to come on automatically when the ignition is switched on,
 my main lights and side lights do not work at all when i turn the ignition on,
i changed side light bulbs cos it looked like one had blown,
both head light bulbs look good but aint got any way of testing them Tongue
« Reply #8 on: May 20, 2013, 07:30:08 AM »
You will probably have a lighting relay switched by the ignition circuit for the headlight . If both side and headlight are not working I would expect the problem to be a multi connector has come apart.
I suggest that you either borrow a test meter or make a simple tester using a bulb (known to be good) and a piece of insulated wire.
kinkytriker
« Reply #9 on: May 20, 2013, 07:37:19 AM »
cheers for info,will check multi connector and get my hands on a meter, thankyou Grin
kinkytriker
« Reply #10 on: May 22, 2013, 06:46:48 AM »
have changed all my bulbs and still not a glimmer of light,
a mate has suggested that i could have moister in my wiring
so that will be fun trying to find where it is damp lol   Tongue
« Reply #11 on: May 22, 2013, 07:45:41 AM »
The only place that might cause you a problem is at a connector so that's the place to start
« Reply #12 on: May 22, 2013, 08:59:49 AM »
Just spray contact cleaner on all the plugs and sockets of the wiring harness.
kinkytriker
« Reply #13 on: May 22, 2013, 08:11:25 PM »
got hold of a multimeter today, will do some testing and see if any thing is a miss,
hoping it will be a easy fix Roll Eyes
« Reply #14 on: May 22, 2013, 09:13:42 PM »
Even if a connecter hasn't come apart, it can lose the connection if it's dirty - pull apart and clean with some fine emery paper or squirt with WD, put a bit of vaseline on to stop it happening again (once you find which one!)
