April 16, 2026, 11:19:47 PM *
Pages: [1] 2 3
Author Topic: wheels  (Read 12331 times)
« on: May 13, 2013, 08:58:50 PM »
ok so thing are now progressed to the stage of needing some wheels. ihave banded steels but fancy some alloys BUT
where do i get such things in 4x4" or does everyone use 4x100??
if using 4x100 how do you get them to centre properly as there are no spigot rings for reliant Undecided Undecided
thanks again for help and advice
« Reply #1 on: May 13, 2013, 09:36:14 PM »
I have some 100 PCD alloys. You can use wobble nuts to allow for the slight difference between 100mm and 4", or get a convertor plate ( I think some people just  put them on but sounds dodgy to me). Convertor plates are expensive on ebay, looking for some at a sensible price myself Smiley I have only found wobble nuts on metric threads, having trouble finding them for 3/8unf reliant studs.
« Reply #2 on: May 14, 2013, 06:02:12 AM »
Choice of alloy wheels is very limited in 4 x 4"(101.6)
Minilites are available usually up to 13" dia. but found Frontline Spridget list 5.5J X 14"
trev
« Reply #3 on: May 14, 2013, 08:28:47 AM »
i use mini alloy wheel nuts ,they have a tapered head that holds the wheel nice and tight,cheap enough on ebay.
« Reply #4 on: May 16, 2013, 04:51:33 PM »
As Andy says,adaptors are quite expensive,and will give you a wider track.I re-drilled my Reliant hubs to 4 x 100 . Theres only a fraction in the difference ,so it was hard to do . Tried using a drill stand,but ended up using a mill to bolt the hubs down real tight,then drilled really slow.Used larger diam studs to accomodate the wheel nuts of the alloys.I f you have shaved a small amount off the hub "corners" to fit Nova discs,the holes will end up very close to the edge. I welded the studs from behind,and I havent had a problem. Manky gave me the idea ,and he hadnt had a prob with this either.Unfortunately I havent got the use of the mill any more,or I could have done them for you(huge,pathetic,argument at work re use of machinery for personal use!)
 Shameless thread jack ..sorry..getting desperate.Has anyone got any 13"- 4 x 100 or 4 x 4" old skool 3 spoke alloys. Spokes are like the tsw rims.Thanks
« Last Edit: May 16, 2013, 04:59:49 PM by ROD » Logged
« Reply #5 on: May 16, 2013, 07:22:50 PM »
Reworking the hubs is a good idea
« Reply #6 on: May 16, 2013, 08:03:49 PM »
yep i've thought about the possability of doing that but thought it may not be diy so i'll maybe try some of the
local engineers and see what the cost might be
« Reply #7 on: May 16, 2013, 08:08:18 PM »
i did my own when i had my trike and i upped the stud size,, i actually used some ford studs that i had in stock ,
« Reply #8 on: May 16, 2013, 08:16:33 PM »
I use these 4" to 100mm there 25mm thick. no drilling or altering the hub
http://www.ebay.co.uk/itm/230977584811?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_702wt_1170
« Reply #9 on: May 16, 2013, 08:46:18 PM »
Hmmm....£89 sounds a lot,but by the time youve ponced around finding a machine shop/getting hubs to them etc,I suppose that aint too bad,and also a easy,quick fix.Do they come with studs for the 4 x 100 set up? The studs are about £1/£1.50 each IIRC. Alot of people dont like adaptors,but I reckon they are ok in most circumstances.
« Reply #10 on: May 16, 2013, 09:11:20 PM »
if i buy this it would make some of those adaptors
http://www.ebay.co.uk/itm/ALUMINIUM-FLAT-BAR-BILLET-6-x-1-x-300mm-/121110662234?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item1c32c20c5a
just hope my drilling is up to scratch Roll Eyes Roll Eyes
« Reply #11 on: May 16, 2013, 09:16:32 PM »
no studs. depends on what wheels you fit. yes they seam a bit dear. but as you said by the time you take the hubs off find some one to do it. its not a bad price.
there was some one else on ebay selling them i brought a couple of sets for 20/25 pounds
« Reply #12 on: May 16, 2013, 09:19:19 PM »
what grade is it Huh
« Reply #13 on: May 17, 2013, 06:02:30 AM »
[/quote]
now there's a thing i never thought of,i'll ask the question and see what they say
« Reply #14 on: May 17, 2013, 07:24:39 AM »
I wouldn't use aluminium for adaptors.
 Spacers perhaps but not adaptors.
Pages: [1] 2 3
