« on: May 12, 2013, 08:50:23 PM » |
« Reply #1 on: May 12, 2013, 08:59:09 PM » |
dosn,t look fit for anything as most of its ,missing ,,
« Reply #2 on: May 12, 2013, 09:03:08 PM » |
that's cause it's the old one,the ebay link's the new one
« Reply #3 on: May 12, 2013, 09:04:33 PM » |
Most Reliants used Mini brake parts didn't they?
« Reply #4 on: May 12, 2013, 09:06:49 PM » |
later one's maybe but mines single piston wheel cylinders
« Reply #5 on: May 12, 2013, 09:07:58 PM » |
Oh. Never seen a single one.
« Reply #6 on: May 12, 2013, 09:13:38 PM » |
like this  rear brake adjuster
« Reply #7 on: May 12, 2013, 09:16:20 PM » |
like this  rear brake adjuster lockheed also fitted on some fords , the adjuster youre after is very,,very , common and even fitted on dumper trucks and small tractors with mechanical brakes ,,
« Reply #8 on: May 12, 2013, 09:18:55 PM » |
Very so similar to trailer brakes.
« Reply #9 on: May 12, 2013, 09:23:12 PM » |
thats it,,,,  memory has just woke up ,,landrover series 1,,2,,and 3 transmission handbrake adjuster ,, so cheapo landrover parts suppliers are probably youre best bet ,
« Reply #10 on: May 12, 2013, 09:24:04 PM » |
thanks Spanner that will give me somewhere to look
« Reply #11 on: May 12, 2013, 09:30:56 PM » |
a&p landrovers do mail order cheap,, as do, www.paddockspares.
« Reply #12 on: May 12, 2013, 09:33:21 PM » |
The cylinder and adjuster look very much like Herald/Spitfire rear brake items to me...........Morrag
fifer
« Reply #13 on: May 12, 2013, 11:23:00 PM » |
Info on my site for the early brake system before they went over to the Mini setup mid 1990,s . The kitten used the mini setup . https://sites.google.com/site/fifersrelianthintsandtips/brakes/brakes-rear-info-on-parts-to-fit-earlier-robin-with-10-inch-wheels Yes that will fit and a very good price when compared to the Rimmer price below Following info from my site link above ; BRAKE ; REAR ; ADJUSTER Reliant Part Number 92206 Used on Vehicles ; Land Rover Series 2 & 3 Triumph Herald Triumph Spitfire all models Triumph TR6 Triumph Vitesse xxxxxxxxxxxxxxxxxxxxxxx Brake Adjuster ; Rimmer part number ;51972 http://www.rimmerbros.co.uk/Item--i-519762 As well as the brake adjuster you will need 2 off Nuts ; 1/4 Inch UNF ; Rimmer part number ; GHF200 2 off Washers ; Shakeproof ; Internal star ID 1/4 { M6 } ; Rimmer part number ; GF321 The Tappet { 2 off required } for the brake adjuster is given as a Triumph TR6 item ; Rimmer part number ; 111054 . .
« Reply #14 on: May 13, 2013, 06:05:05 AM » |
thank for the links spanners and fifer that gives me lots of options,i'll get something ordered tonight
