April 19, 2026, 09:36:31 AM *
Author Topic: Rear axle  (Read 1875 times)
klogan45
« on: May 12, 2013, 01:34:22 PM »
Hi guys, yet another question.
I'm looking for an axle and reliant axles are as rare as hens teeth and real pricey too. So I'm looking at a triumph spitfire diff, the ratio is 4.11:1
Here is the question.......
Would this perform adequately on a virago 535 ? I'm not looking for something stoopidly fast, but a nice steady ride.
Any ideas or comments will be gratefully received.
Thanks one and all.
Regards
K
« Reply #1 on: May 12, 2013, 05:06:24 PM »
That's a similar ratio to a "Rascal" axle, and you will find it a little low unless large diameter rear wheels are used. The Triumph GT6 axle is around 3:86 If I remember correctly, and would be a better bet if you can get your hands on one, although they are rarer than the Spit./Herald types.......Morrag
klogan45
« Reply #2 on: May 12, 2013, 06:56:55 PM »
Thanks morrag.
