March 25, 2026, 12:25:13 PM *
Author Topic: wheels  (Read 7664 times)
klogan45
« on: October 28, 2006, 04:40:38 PM »
Hi Guys,
got me some 2nd hand wheels today. 17" Got 4, two for each trike that I'm working on.
These are 100mmpcd and they do fit....EXCELLENT.
They just need a clean!!!!!!
Thanks for the help with pcd.
« Reply #1 on: October 28, 2006, 05:31:19 PM »
17s? Ooh, them's BIG. Ska Man & I run 15s on ours with 50 profile tyres, while Simon & Flap have 14s on 60 profiles. They're all roughly 24" overall diameter, which gives us good acceleration with a top end of 85-90mph. We have 3 good gears with 4th becoming a sort of overdrive for motorway hauling.
In theory bigger wheels should give you slower acceleration but a higher cruising speed, but be careful you don't go too big or you'll struggle to pull away. I reckon you'll need some ultra low profile rubber on them mate.
klogan45
« Reply #2 on: October 28, 2006, 06:20:27 PM »
Thanks for the reply,  I'm a bit worried now........ hopefully the trike will pull away ok. Going to be really embarrasing if it don't. I will keep to low profiles, the other pair are going on the mini trike that i'm building, hope that ones ok too......
regards
Keith
take care ride safe have fun.
« Reply #3 on: October 28, 2006, 06:37:34 PM »
Not trying to worry you! Haven't tried wheels that big so got no idea how they'll perform. Could be fine. I don't know. If the worst came to the worst, you could swap your Reliant axle for something like an Escort one, which gives you a wide range of diff ratios to choose from. Coincidentally, the Escort & Capri axles use the same bolt pattern as Reliants for the diff/prop shaft flange, although you'd have to make hub adapters for the wheels.
klogan45
« Reply #4 on: October 28, 2006, 06:43:03 PM »
Thanks MM, i'm pretty sure that it will be okay.....best suck it and see, as the bishop said to the barmaid....or was that to the choirboy...lol
regards
Keith
« Reply #5 on: October 28, 2006, 07:11:32 PM »
 Shocked Grin
klogan45
« Reply #6 on: October 29, 2006, 01:05:28 PM »
Hi MM,
any info on wheel adaptors will be appreciated, might like to 'have a go' in my spare time.....if i can find any.....
Thanks
Keith
« Reply #7 on: October 29, 2006, 01:20:31 PM »
PM Saddlebags. He's just made a set for CJ.
lunatic
« Reply #8 on: October 29, 2006, 02:30:44 PM »
My 17"x7 wheels on my beetle are about the same overall diameter as the 15" with 60 series tyres. I use 205 40 r17 tyres stretched onto the rims, I think its about as low profile as you can get? Tyres are kumhos and were about 50 quid each.
klogan45
« Reply #9 on: October 31, 2006, 06:14:08 PM »
here's a pic of the wheels on the trike Smiley
Goodeh!!! Hope that they work ok.
The ugly old git IS me.
regards
Keith
« Reply #10 on: October 31, 2006, 06:59:24 PM »
Hiya -always nice to see who we're chatting to!  Grin
First trike build or are you a veteran of this weird ol' pastime of ours?
klogan45
« Reply #11 on: October 31, 2006, 07:26:03 PM »
Hi mm,
1st time builder....got the bug REAL bad...got an auto mini trike on the go too. Am going to finish the virago first though, easier and quicker than a 'scratch' build.
Regards
Keith
« Reply #12 on: October 31, 2006, 07:29:05 PM »
Go for it!  Grin
klogan45
« Reply #13 on: October 31, 2006, 09:55:20 PM »
Do you like the wooden suspension Shocked ? Needed to do that as the shocks Shocked are not mounted to the swinging arm yet.
regards
Keith
