April 25, 2026, 05:21:00 PM *
Author Topic: Bronze welding with a tig  (Read 6436 times)
« on: March 18, 2013, 08:19:47 PM »
OK been let down with a promise of some acetylene,
But i have a tig welder,Has anyone done this if so what rods did you use and how successful was it.
« Reply #1 on: March 18, 2013, 10:48:56 PM »
If you have a Tig welder why would you need to Bronze weld Hunter? Morrag
« Reply #2 on: March 18, 2013, 10:54:41 PM »
I'm using some T45 to modify an existing frame that i bronze welded.
And if i don't get it right, I may get my P45 Grin
« Reply #3 on: March 18, 2013, 10:55:37 PM »
Bronze weld Hunter to Morrag
sounds painfull to me  Roll Eyes Roll Eyes
« Reply #4 on: March 18, 2013, 11:34:18 PM »
Yes ive seen it on youtube! Will look for the ved when ive a little more time
« Reply #5 on: March 18, 2013, 11:58:28 PM »
Thanks Chewie.
« Reply #6 on: March 19, 2013, 01:25:47 AM »
http://www.youtube.com/watch?v=F2_hXQ4ABrg
« Reply #7 on: March 19, 2013, 10:48:39 AM »
Thanks Chewie, It looks like the same rods are used for both gas and tig.
« Reply #8 on: March 19, 2013, 12:10:04 PM »
Yeah just go cooler when brazing on the tig
« Reply #9 on: March 19, 2013, 02:52:01 PM »
Never thought about doing that.  Got to get me a tig .
« Reply #10 on: March 20, 2013, 11:11:44 PM »
Bronze welding with TIG is fine but you need Zinc free roods not the ones that you use for gas welding.
The Zinc boils off when tigging and ruins it.
I bought some rods a while back and it works fine. £80 per kilo though!!!
http://www.choppit.co.uk
« Reply #11 on: March 20, 2013, 11:43:12 PM »
Thanks ByzMax,That's the answer i was looking for.
« Reply #12 on: March 27, 2013, 08:43:05 PM »
Having problems getting rods locally,
Bryzmax do you have any codes for these rods,
Any help would be appreciated.
« Reply #13 on: March 29, 2013, 12:10:05 PM »
The ones I used are Sifsil no 968. or Sifsil No 32
Easier to buy over the net
If you search sif sil for tech data as to which type to use as the ones I use may not be suiatble for what you are doing.
Hope that helps.
« Reply #14 on: March 29, 2013, 12:34:32 PM »
Thanks Byzmax will investigate.
