January 17, 2026, 07:47:44 PM
Bike Tech
Valueable lesson learnt
Topic: Valueable lesson learnt (Read 2739 times)
gsxbobber
March 05, 2013, 07:16:32 PM »
I must remember not to take to much notice of one make motorcycle forums when it comes to setting engines up all the clap trap about jetting carbs when running with mods i started with there so called ideal settings .It was way out more soot than a coal man 4 different sets later and now waiting for yet more ,and the moral i will be still only up one size
Re: Valueable lesson learnt
March 05, 2013, 07:31:06 PM »
I've found it's best to start with standard jets (you already have them anyway) and work up from there.
March 07, 2013, 03:13:07 PM »
In very general terms 'Olds's' about on the money, as the usual reason for modifying jetting these days is due to fitting a less restrictive, aftermarket, silencer, and this rarely requires a main jet increase of more than 'one size' up for most four-strokes, 2 strokes are another matter, so set up what you have CORRECTLY first,to ensure clean running over the complete range of opening, then do a plug "chop" or two to assess where you are top end wise......................Morrag
