April 19, 2026, 12:59:28 AM *
Author Topic: tips on mating a subaru to vw beetle bellhousing  (Read 7389 times)
v8dodger
« on: February 23, 2013, 02:19:33 PM »
iv  got a  old  1800  ea 82 boxer and  need to fit to a , old beetle box. this is were im at on this so far in my thinking, 200 or so mm clutch fly wheel from a 1600 engine, give this to a shop i  no that will spin it on a lathe and reduce or sleeve (depending what way i need to go with it), the center to fit the end of the crank then a  device made to fit the centers of both fly wheels so i can drill  and fit to new engine, the adapter plate is already in my head and should not be to much effort, its mainly the flywheel.
im aware that some  would think the 1800 is pointless when there is 2000 ltr out there ready , but simple fact is iv got the 1800 and  will work out better for me in the long run. thanks  for any advise you can give. Smiley
« Last Edit: February 23, 2013, 03:47:44 PM by v8dodger » Logged
nabsim
« Reply #1 on: February 23, 2013, 11:03:56 PM »
I have an 1800 engine with 200mm clutch that I was thinking of putting on my VW Dodge. Jump on www.volkszone.co.uk into air cooled technical and ask them there. Jinx on there sold me the 200mm clutch modified to mate the 1800 to my 1600 IRS gearbox. It wasn't much needed modifying but I can't remember what, Jinx will tell you
nabsim
« Reply #2 on: February 23, 2013, 11:05:26 PM »
Sorry Dodge, after I had pressed send I noticed the Subaru bit, mines a transporter 1800. Still ask on Volkszone they have a section dedicated to mating different engines to VW boxes
v8dodger
« Reply #3 on: February 24, 2013, 01:13:32 AM »
thanks nab i will have a look, iv  sat down , done tons of reading, even found a pdf  on line from a volkswagen mag s forum  on how they did it, and every item im finding so far lol is , and i quote . you need to buy  our kit , im sure in fact very sure what your saying is going to work. home diy, just hope its a cheaper way than the kit lol  i iwll go look on there forum Wink
« Reply #4 on: February 24, 2013, 08:28:55 AM »
You do take on some problems Dodger! Grin
« Reply #5 on: February 24, 2013, 10:03:33 AM »
Some folk just like doing things the hard way  Grin
v8dodger
« Reply #6 on: February 24, 2013, 10:05:28 AM »
it keeps me ticking over, figuring out stuff. Smiley
nabsim
« Reply #7 on: February 24, 2013, 01:07:16 PM »
I have seen something about the adapters on volkszone but not read that much, it was just a bit of machining I think, possibly even filing for mine.
End of the day it's only going to be some sort of make up plate to join the two bits together, while it may be brain surgery to me there will be lots of she'd heads capable I would think.
Main thing is check costs of buying it and find what it costs to get it done yourself then do what's best if you can afford it.
Thinking about this a bit more Dodge, didn't Thunderace use Subaru engine and one of the Subaru gearboxes on his trike and make his own wishbones type rear end?
Is that an option?
« Reply #8 on: February 24, 2013, 02:21:24 PM »
http://www.tsrengineconversions.co.uk/
v8dodger
« Reply #9 on: February 24, 2013, 02:45:49 PM »
Is that an option?
not as got rid of the gear box ages ago it was full of water from siting ous side, no the engine.
v8dodger
« Reply #10 on: February 24, 2013, 02:47:47 PM »
thanks itresting stuff will look firther in to it with them. Smiley
nabsim
« Reply #11 on: February 24, 2013, 04:21:59 PM »
Who made you the adaptor to put the v8 on the VW trike Dodge?
v8dodger
« Reply #12 on: February 24, 2013, 04:28:22 PM »
funny thing this, i was looking for a auto box  for the trike and stumbled upon the  the  adapter plate, dont know were it come from, but have found a v8 one and a Subaru for  400 euros in germany but dont have good rep. i will convert a flywheel  im very sure i can do a diy adapter based on kevs trike conversion, it looks simple to do. Smiley
