April 26, 2026, 05:36:01 AM
General Tech
LPG Conversion on the cheap
Topic: LPG Conversion on the cheap (Read 5320 times)
The North
February 02, 2013, 12:34:37 AM »
I am considering runing my Austin Devon on LPG, This car i am building as a daily drive. So economy measures put in place on assembly were my first thoughts here, i planed om making a small 2 or three gallon petrol tank and fit that with its neck same place as the devons and get a lpg tank to fit beside it in the area below the boot floor same place as the original tank.
I have never converted a car properly to run on lpg i did over 15 years ago have a suzuki jeep i fitted a cat forklift vaporizer and other bits and bobs like fitting an electric fuel pump rather than the mechanical etc etc and it did run on a normal forklift cylinder in the back.
Now i know that insurers etc are far more demanding now on lpg fitment and probably regs exist i am sure, but a vaporizer is a vaporizer and on a simple mgb engine with no ecu turbo etc a simple conversion must be a possibility.
Now my beam products vaporizer was rated at 60hp and worked ok on the 1300 suzuki. but i sold it long ago and not sure what would be my cheapest route to a used kit of parts for this conversion. I obviously will look on ebay but any advice technically that may help me get a conversion kit together and fitted in the proper most effective way would be very helpful.
I plan on getting the car tested at a lpg instalers in yorkshire but want to get what i can and instal it myself. HELP!
phunkie hiboy
Re: LPG Conversion on the cheap
February 02, 2013, 11:01:10 AM »
Have a look on eBay here's always plenty of 2nd hand kits available .....
http://www.ebay.co.uk/sch/i.html?_nkw=lpg+kit&_sacat=0&_odkw=lpg+kit+v8&_osacat=0&_from=R40
February 02, 2013, 07:07:49 PM »
Kapri might be the man to talk to. He's fitted several LPG/petrol conversions & I think is running his classic Econoline pick-up on purely LPG.
phunkie hiboy
February 02, 2013, 09:19:06 PM »
Funnyly (is that a proper word) enough I was fitting LPG systems (2or3 a week) 10 years ago, that's when I first moved into my shop in Hook.
February 02, 2013, 10:29:29 PM »
Then Mr Phunk would be the chap to talk to!
The North
February 02, 2013, 11:45:17 PM »
I will end up trawling ebay for one, and as fr a workshop in HOOK? that must be in Hampshire bot the Hook very close to me near goole east yorkshire am i corect think i have heard hook in Hampshire
Reply #6 on:
February 02, 2013, 11:57:32 PM »
Yup, Hampshire. Junction 5 of the M3.
phunkie hiboy
Reply #7 on:
March 13, 2013, 09:26:58 PM »
Just seen this ..............
http://www.rodsnsods.co.uk/forum/stuff-sale/lpg-kit-75964
The North
Reply #8 on:
March 14, 2013, 04:46:39 PM »
Quote from: phunkie hiboy on March 13, 2013, 09:26:58 PM
Top man made contact let you know what happens, do you recon it will work on my devon project phunkie HB. ?
phunkie hiboy
Reply #9 on:
March 14, 2013, 07:02:28 PM »
Don't see why not. You'll have to make some arrangement to cut the fuel at the carb so it doesn' run on both. there was some sort of valve I think, but it's years since I did a carb one. I'll see what I can find in the archive!!
