April 25, 2024, 02:00:06 PM *
Author Topic: MSVA Confusion  (Read 4768 times)
« on: January 20, 2013, 09:23:05 PM »
Hi All
I am now befuddled by the braking requirements in the MSVA manual  Undecided  Huh
It reads:
3. Check that every motorcycle tricycle or motorcycle quadricycle is equipped with either;
a) two independent service braking devices fitted, one acting on the front axle/one acting on the rear axle which together operate the brakes on all the wheels
b) a single line service braking device that operates the brakes on all wheels
and
c) a secondary (emergency) braking device ( that may be the parking brake)
d) a dual/tandem service braking device which operates the brakes on all wheels
and in addition to any of the above
e) a parking brake device that operates on the wheels of at least one axle
Acceptable combinations are: a) & e) or b),c) & e) or d) & e)
4. Check that every other tricycle or quadricycle is equipped with;
a) a foot controlled service brake device, that operates on all wheels
b) a secondary (emergency) brake device (that may be the parking
brake), and
c) a parking brake device, that operates on the wheels of at least one axle
I am building a reliant based trike with a GS1000 front end. Which category will that fall into ?  I ask as I am still deciding if to link the front and rear brakes to the footpedal, or put a hand control on the handlebars. Reading the above if the vehicle is classified as other tricycle then i MUST link the brakes
« Reply #1 on: January 20, 2013, 09:29:26 PM »
I'd assume "Motorcycle tricycle" refers to any trike with a motorcycle style front end, ie,forks & a single front wheel?
If that's the case then parts 3 a or b apply:
« Reply #2 on: January 20, 2013, 09:34:43 PM »
Well, thats what I'm hoping, I wondered if it meant bolt on trikes for bikes. So what is other tricycle ?
« Reply #3 on: January 20, 2013, 09:38:33 PM »
Not sure. Reverse trike maybe, with 2 wheels at the front? Or sidecar style with front & one rear in line & the other offset to one side? Dunno.
« Reply #4 on: January 20, 2013, 10:19:28 PM »
Must admit the wording could be simpler but I read it as "motorcycle" being one you sit astride with handle bars anything else being "other"
« Reply #5 on: January 21, 2013, 05:59:07 AM »
Motorcycle tricycle is under 450kg unleaden weight.
WAYNE999
« Reply #6 on: January 21, 2013, 07:16:55 AM »
Tell me about  it . I'm beggining to think my heads going to pop.
Mendalot
« Reply #7 on: January 21, 2013, 08:00:44 AM »
Do you have to stipulate what vehicle you are building when you apply for a VIN number?   if so make sure on all documentation from that point, it is listed as a Motorcycle Tricycle.   May save any confusion later on.
« Reply #8 on: January 21, 2013, 09:20:39 AM »
As mentioned above , definition is by weight, should be near the front of the MSVA document.
WAYNE999
« Reply #9 on: January 21, 2013, 01:11:59 PM »
I'm going to my local office this Friday to apply for a VIN I'll let you know how I get on
« Reply #10 on: January 21, 2013, 07:21:15 PM »
Here's another thought, the BRA three wheeler, which was a bit Morgan 3 Wheeler-ish, and ceased manufacture a few years back, albeit in kit form, used a pair of disc braked front wheels, whereas the single Honda CX rear wheel retained it's drum brake as a hand brake ONLY, and was not connected to the two fronts in any way, sooooo......., how did that pass muster? or indeed the required Test,I'm interested, so if anyone has the definitive answer to this one, let's have it please Undecided Undecided Undecided Undecided Undecided :-\Morrag
« Reply #11 on: January 21, 2013, 07:24:53 PM »
Hi All
GOT IT - in the Glossary:
Motorcycle tricycle
A tricycle which is designed and constructed with a single front wheel and motorcycle type suspension and steering.
So, thats good - now I feel comfy having seperate front and rear brakes - so long as I dont go over 1000Kg !!
