April 28, 2024, 05:58:33 PM *
Pages: 1 [2] 3 4 5
Author Topic: Trailing  (Read 17711 times)
« Reply #15 on: January 03, 2013, 08:26:00 PM »
Done similar to that in the past on stuff. Its deffo an answer to the problem,but looks a bit naff!
« Reply #16 on: January 03, 2013, 08:28:25 PM »
Welcome to my world  Grin
bitzman5
« Reply #17 on: January 03, 2013, 10:34:27 PM »
you can use 1/4 ply for sides roof and cover with 1mm alloy or the one side plastic coated alloy sheets floor 18mm for rigid strength and chassis is very minimal as strength in wood cube screws and bonding agent
« Reply #18 on: January 04, 2013, 02:20:00 PM »
See Rod, you l know it makes sense Smiley
« Reply #19 on: January 04, 2013, 04:47:52 PM »
Ive already formulated the plan and built it in my head mate! Broached the subject of camping in France with swmbo ,the look I got said it all!.........................................................so I wont be building one afterall!! Grin
Mendalot
« Reply #20 on: January 04, 2013, 09:10:03 PM »
How about the stuff I have used on the dash of my kit car, Alupanel, two sheets of 0.30mm ally sheet sandwiching a polythene core, very light and a brushed aluminum non scratch surface. Comes in 8 x 4 sheets. May be too flexible for the floor, but ideal for sides. By MultipanelUK ... http://www.multipaneluk.co.uk/products/sign-materials/alupanel/
« Reply #21 on: January 04, 2013, 11:57:18 PM »
Mendalot,How thick is this stuff.
« Reply #22 on: January 05, 2013, 06:32:50 AM »
Worth considering , I like the idea it comes in different colours.Sounds pricey?
« Last Edit: January 05, 2013, 06:37:44 AM by ROD » Logged
Mendalot
« Reply #23 on: January 05, 2013, 10:02:14 AM »
Its 3.5mm and fairly rigid in short bits, the bit for the centre consol in the picture below took a fair bit of force to bend to the shape required. I can send you a sample if required as I have some left over. I get it from a local bloke who makes shop signs and facias, I seem to remember its about £85.00 for a full a sheet.
http://i390.photobucket.com/albums/oo343/PDSheridan/Dash012.jpg
Trailing
http://i390.photobucket.com/albums/oo343/PDSheridan/Electrical030.jpg
Trailing
http://i390.photobucket.com/albums/oo343/PDSheridan/Electrical014.jpg
Trailing
« Reply #24 on: January 05, 2013, 11:06:36 AM »
Nice dash!
« Reply #25 on: January 05, 2013, 01:10:05 PM »
8 X 4 sheets? Looks good stuff but could work out expensive . Would need 2 sheets for the sides of a teardrop,plus whatever the roof is done in.
 Whether it be aly or ply,it would still condensate inside,meaning covering with thin carpet.
 A main concern I've always found is the hinge mechanism and the way the door/flap seals. I tried various ideas,but none stopped the rain coming in ,especially as youre travelling when the rain is 'driving' into the gap.I would open the lid to find a line of water across the floor under the hinge area. I ended up having to gaffer tape the join when travelling.When the lid is raised in use,what stops the rain getting in the opened gap at the hinge? There are supposed to be 'piano' type hinges which by design are self sealing,I think theyre made of plastic or nylon type stuff, but Im not so sure even they would work efficiently.
« Reply #26 on: January 05, 2013, 01:32:28 PM »
I have two sheets of this stuff, A mate of mine works for a well known House building company,
And brought them home for me,I also have two new sheets of ally about 2mm thick.
  Nice dash.
« Reply #27 on: January 05, 2013, 11:08:46 PM »
That'sprobably why the Glassfibre ones don't have a hinged section!
MIXA
« Reply #28 on: January 24, 2013, 02:02:57 AM »
This site might help free plans for a tear drop      http://www.mikenchell.com/images/GenericBenroyPlans.pdf
paulywombats
« Reply #29 on: January 24, 2013, 05:03:15 PM »
Thanks for the link, found it really interesting. Got a contact with a CNC router, going to pass it on to him and see if we can knock one up.
Living on a wing and a weld
Pages: 1 [2] 3 4 5
