March 25, 2026, 05:52:08 AM *
Author Topic: Reliant wheels  (Read 6511 times)
klogan45
« on: October 09, 2006, 06:37:20 PM »
Hello all....... getting ther with the virago 535 conversion. managed to get a reliant axle...EXCELLENT!!!!!!! But, and aint ther always one?Huh?
What wheels will fit? I've had a look at the PCD chart and could not find anything with a 4inch pcd..... I thing that I've got the right term!!!!) Anyway can anyone tell me what will fit on a reliant axle....except for reliant wheels. Looking for something around 14, 15 or 16 inch. Size is important, the wife has been right all these years!!!!!!
Thanks guys,
regards
Keith
longboarder
« Reply #1 on: October 09, 2006, 07:41:55 PM »
Apparantly early 3 series BMW's & VW Golfs that are 4x100 fit, but i'm sure someone will be along shortly to confirm or not.
« Reply #2 on: October 09, 2006, 08:11:31 PM »
Hiya, loads of modern Vauxhalls use 4"PCD. The little boyracer's Novas & Astras & the like. Halfords will flog you a set of 4 nice shiny alloys with tyres already fitted for a couple of hundred quid, then you can flog the other 2 to another triker. Or Moggy Minor wheels will fit; new Minis, some Hondas, a few models of Daewoo & Daihatsu, Mazda MX5s, all the Proton models, Renault Clios, Rover 200 & 400s, even Volvo 440, 460 & 480s.
Check the PCD chart again -there's loads.
longboarder
« Reply #3 on: October 09, 2006, 08:22:29 PM »
Actually there 4x100  Wink
« Reply #4 on: October 09, 2006, 08:37:40 PM »
O.K, yes they're 100mm & 4 inches is 101.6mm.
0.53mm difference on the hole centres. Half a millimetre. About 5 fag papers.
Trust me, they'll fit. Obviously, ideally they should be 4", but if you're using second hand wheels & studs, they've probably worn more than that.
« Last Edit: October 09, 2006, 08:54:29 PM by Manky Monkey » Logged
« Reply #5 on: October 09, 2006, 10:38:43 PM »
I've always wondered if my wheels came from an Astra - only cos of the 'A' on them!
« Reply #6 on: October 09, 2006, 11:30:37 PM »
Them's nice wheels Bobbi. Presumably that's the wheel manufacturer's name. I think mine have actually got BG on them -maybe we should do a swap!
Keep thinking about changing mine for something a little deeper dished. I like the look of Flap's Wolfies but they wouldn't really match my front wheel. I bid on a set of 4 chrome Pajero 4x4 wheels on Ebay the other day. Went for 46 quid in the end. A bargain. My highest bid was 45.
klogan45
« Reply #7 on: October 10, 2006, 05:17:26 PM »
Hi Guys,
Thanks a million, that's sorted that one for me. I had a look at the pcd chart and yes there are loads, did'nt realise that the pcd was not totally crucial. Went to the local wheel shop and the bloke there was really unhelpful. Gave the impression that I'd kill meself if the fit was not EXACT, half a mm does'nt seem a great deal. I believe that I can get washerey things (technical term ....NOT) with the holes sightly oversixe to allow the nuts to sit central.
Thanks again guys
Regards
Keith
Ride safe, have fun, take care
« Reply #8 on: October 10, 2006, 07:52:16 PM »
Hiya, obviously they should be spot on, but you're talking half a millimetre out on each wheel stud -you could lean on the wheel brace when you do 'em up & bend the studs more than that. Once the threads have worn a bit you'll get more play in them than that. Don't try & squeeze 4 1/4" s onto 4" hubs -I've seen it tried, but in this case we're talking a minute difference. I ran Vauxhall fitting wheels on my green trike for 4 1/2 years with no problems. Ska Man's now running Rover wheels on the same axle.
klogan45
« Reply #9 on: October 13, 2006, 04:15:41 PM »
Thanks to all for your help regarding the wheels, going to have a look around at the week end for some.
Thanks again
Take care, ride safe, have fun.
Keith
« Last Edit: October 15, 2006, 03:23:28 PM by klogan45 » Logged
reliantman
« Reply #10 on: October 13, 2006, 05:30:59 PM »
The bloke in the wheel place was probably covering his arse by saying that.
It is not good engineering practice to stress the studs, but people have been fitting
100mm PCD wheels for ages.
« Last Edit: October 13, 2006, 09:35:36 PM by reliantman » Logged
« Reply #11 on: October 13, 2006, 08:47:17 PM »
Yeah -what he said.
