saddlebags
« on: October 06, 2006, 06:41:00 PM » |
Hi manky i seem to recall making either wheel adapters to convert from 4 to 5 stud or was it a propshaft adaptor to change the pitch of holes,any how can you remember what mateirial they where and how thick it was im making similar adaptors for CJ.
« Reply #1 on: October 06, 2006, 10:13:43 PM » |
Doug made a pair of wheel adaptors for my Moggy Minor to convert from 4 to 4 1/2" PCD but that was a million years ago when he owned his own business. Did you make a similar set for Simon's black Reliant? He's running 5 spoke Revolutions from an old Capri, which would be 4 1/2" Ford pattern so must've been adapted to the Reliant's 4" PCD. They were powder-coated mild steel & about an inch thick -enough to recess the heads of the wheel bolts down flush.
saddlebags
« Reply #2 on: October 07, 2006, 05:08:40 AM » |
Cheers manky thanks for the memory jog i see it all now said the blind man.
« Reply #3 on: October 07, 2006, 09:51:10 AM » |
Me jogging some one else's memory?! That's a first!
reliantman
« Reply #4 on: October 30, 2006, 11:04:25 AM » |
Saddlebags. A question for you. I have a Subaru sumo mini van engine/gearbox back end which I am slowly turning into a trike. The stud PCD is 100mm on the sub, and I have some Nissan Z240 ally wheels with 4 1/2 inch PCD which I would like to fit on it. Now I have already got one front hub off a Bedford Rascal van, which I cut by hand to make an adaptor, which happens to be 4 1/2 inch PCD. The four disc mounting holes are 100 mm, but the slots where the bolt heads would have to sit need machining out, if you get what I mean. If I get another hub, would you be able to take some metal out for me, and how much would you want to do it?
Cheers.Doug
saddlebags
« Reply #5 on: October 30, 2006, 10:18:42 PM » |
I think i know what you mean but i'd need a sketch to be sure but it sounds like a £20er to me, are you local to basingstoke?
« Reply #6 on: October 30, 2006, 10:22:36 PM » |
I've got another job for you too mate. Brock, (my brother Steve), needs a part for his drag car. I'll be in touch once he's emailed me a sketch.
saddlebags
« Reply #7 on: October 30, 2006, 10:29:53 PM » |
No worries look forward to hearing from you.
reliantman
« Reply #8 on: October 30, 2006, 10:34:57 PM » |
Not really mate. I'm in the next country  but I could post them. There is is no big hurry as I have to buy one more rascal hub. I would have had two but I was still trying to get the hub off the van as the scrappy was loading it on his wagon, and had to let it go in the end. I will probably be coming back to Oxford around xmas, so I could nip over then. I will take a picture in the morning. Thanks.
« Last Edit: October 30, 2006, 10:41:05 PM by reliantman »
saddlebags
« Reply #9 on: October 30, 2006, 10:37:44 PM » |
Look forward to hearing from you, if you have any other parts you need looking at we'll sort them at the same time cheers Scott.
reliantman
« Reply #10 on: October 31, 2006, 01:37:48 PM » |
Scott. Please see attached pic. What I have in mind is to bore out the shoulders of the mounting holes, approx 5-10mm, so that there is enough room for the nuts to be tightened up.
Wulfgar
« Reply #11 on: October 31, 2006, 01:53:46 PM » |
foxthound
Piston broke
« Reply #12 on: October 31, 2006, 02:25:29 PM » |
Nice to see my 'back-of-fag-packet' blueprint getting some air!
D'ya call that an engine?
Wulfgar
« Reply #13 on: October 31, 2006, 03:12:20 PM » |
Nice work mate, it seems to be doing the rounds.
klogan45
« Reply #14 on: October 31, 2006, 06:11:49 PM » |
Hey guys, just what i'm looking for, wheel adapter plans. I can now see how they go!!!!  Thanks for posting them. Regards Keith
