I have had the heel on a set of modern points wear down in a couple of days .
When I checked the heel I found that it was so soft that I could dig my nail into the material
Is your distributor the newer type with the sliding points operated by the plastic white fork which sits over the pin on the baseplate { often usually coloured Blue } or the earlier points { often usually coloured Red }?
EARLY POINTS LUCAS ................. PART NUMBER ....... DSB108
CI........................ PART NUMBER ....... CS132
INTERMOTOR ....... PART NUMBER ....... 22580
MINISPARES ......... PART NUMBER ....... GCS2118
MOTAQUIP ........... PART NUMBER ....... VCS108
QUINTON HAZELL . PART NUMBER ....... XCS132
UNIPART ............. PART NUMBER ....... GCS3004
LATER SLIDING POINTS LUCAS ................. PART NUMBER ....... DSB191{C}
CI........................ PART NUMBER ....... CS179
INTERMOTOR ....... PART NUMBER ....... 23451E
MINISPARES ......... PART NUMBER ....... GCS2261
MOTORCRAFT ....... PART NUMBER ....... EDP109
QUINTON HAZELL . PART NUMBER ....... XCS179
UNIPART ............. PART NUMBER ....... GCS3005
