Originally posted by one arm bandit ;
thanks fifer the engine should be a 96..but it has been changed from the donner at some point to 4m is that 84?? i assume the gearbox is oridginal 96??, i thought oil to start with, but after adjustment it hasnt slipped??
If your
4M engine number starts with a 7 and has a " E " at the end of the number then it is a 1984
HTE {
Yellow
Top
Engine } and would have originally been built in Dec 1984 fitted with the carbon clutch .
If your
4M engine number starts with a 9 and has a " B " at the beginning of the number then it is a 1994 engine and would have originally been built in Dec 1994 fitted with the roller clutch .
Could you do me a favour and PM the engine numbers and any other info you have about the original Reliant doner so that I can add it to my DATABASE at
https://sites.google.com/site/fifersrelianthintsandtips/engine-numbers .
im sure mines the roller type thrust but not 100% ive had it out previous on rebuild but didnt take much notice just made sure it spun round and had little slop. either way im gonna need a clutch some time,and will remember carbon pull away roller push on Wink ile leave it with not spring for tomorrows trip the get the gearbox out in the week and check it all over.. thanks fifer
my pressure plate has many finger apose to three big ones if that helps identify the thrust??
Therin lies the clue
It has to be a roller as the carbon lining is fixed and cannot be rotated
