April 22, 2026, 11:55:47 AM *
Pages: 1 ... 6 7 [8] 9 10 ... 36
Author Topic: A little progress  (Read 160737 times)
andyrennison
« Reply #105 on: November 05, 2012, 10:00:08 PM »
Looking very good Smiley
« Reply #106 on: November 06, 2012, 07:03:18 AM »
Great progress
« Reply #107 on: November 09, 2012, 11:17:50 PM »
not much done this weekend but every little help's
http://i1056.photobucket.com/albums/t373/Eddie096/644331F6-FA3A-4546-B62B-5DAFA75F360F-615-0000008547144BE3.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/DB74CD7E-B9F6-41D3-9516-A31076D615FE-615-0000008561CA9D9F.jpg
A little progress
working until next sunday but might try and do a bit during the week
steven brock
« Reply #108 on: November 10, 2012, 12:43:21 AM »
Is the rad going inside or outside the engine cradle?
« Reply #109 on: November 10, 2012, 08:34:20 AM »
it will be inside the cradle with a fan shroud to keep fingers safe
steven brock
« Reply #110 on: November 10, 2012, 09:46:47 AM »
Keeping the fan then Smiley
« Reply #111 on: November 11, 2012, 12:36:04 AM »
yeh for the time being anyway til i see how it goes and then maybe go mini 2 core rad and lecky fan if needed
« Reply #112 on: November 11, 2012, 09:06:30 AM »
Lookin' good!
Quick word of caution to prospective builders- don't forget to leave enough room under the top tube, particularly at the back, to get the engine rocker cover off to set the tappets & to remove the engine from the frame. Not that I've ever built a frame then found I couldn't, honest.  Tongue
dave 67
« Reply #113 on: November 11, 2012, 09:16:20 AM »
Re: A little progress
« Reply #111 on: Today at 12:36:04 AM »
I didnt know about the fan thing Come on then what's wrong with the fan and why change it
never to old to learn
steven brock
« Reply #114 on: November 11, 2012, 10:35:32 AM »
Dunno I kept it on mine but see others ditch it
« Reply #115 on: November 11, 2012, 12:01:37 PM »
Nowt wrong with the std fan except that it's quite offset. If you fit the a Reliant or Mini radiator symetrical to the frame, the fan sticks out on the nearside. The fan is also quite thick meaning you need a large gap between engine and rad.
« Reply #116 on: November 11, 2012, 01:51:55 PM »
I hope that I have left enough room!?? with a bit of tidying of the pipes and stuff that are on top of the engine will leave a bit more room
on that subject is it simply a matter of joining the 2 heater piped together to complete the water circuit?
As far as the fan goes I'm keeping it if i can as i might not want to run a car battery and the less load i have on the electrical system the better i figure it will be and also i already have it so it's free!
steven brock
« Reply #117 on: November 11, 2012, 02:20:16 PM »
Don't forget thermostat housing isn't angled out to the inlet of the radiator if too tight nightmare for the hose to do an s shape to connect I made my own stat housing angled out
http://i1061.photobucket.com/albums/t466/steveatthemorgue/reliant%20trike/B75E080D-ECB7-4B77-A15F-EAD1C788EC2B-553-00000053650FA104_zps5d0dfca4.jpg
A little progress
And yes that was/is a stainless handrail 'end' lol
« Last Edit: November 11, 2012, 02:23:35 PM by steven brock » Logged
« Reply #118 on: November 11, 2012, 03:01:26 PM »
Nice solution to the thermostat housing problem Smiley At the moment I have a very tight s bend and am not really happy with the strain it's putting on the rad. Why the f### did reliant have to be different and not equispace the bolt holes.
steven brock
« Reply #119 on: November 11, 2012, 03:11:06 PM »
Yes I found that out when I designed the flange plate.. I'm getting cut some 3mm mild soon I can add one on for you if you go that route may get some gusset plates too Smiley oo gussets
