April 22, 2026, 12:04:23 PM *
Pages: 1 ... 4 5 [6] 7 8 ... 36
Author Topic: A little progress  (Read 160762 times)
« Reply #75 on: October 14, 2012, 07:45:11 PM »
And then it was on to the engine mounts ,we started with a nut welded on to a washer
http://i1056.photobucket.com/albums/t373/Eddie096/586F53EA-47BA-4991-8BC6-C697D91993A6-520-0000006EFDB80ED5.jpg
A little progress
Then because the engine mount is sitting on top of the frame side rail and the front brace we use 2 printouts from tubemitre to allow for
the 2 angles that we were trying to achieve and overlaid them to come up with this
http://i1056.photobucket.com/albums/t373/Eddie096/BDCCE399-975A-4AC0-9AB6-BA876E2E62A1-520-0000006ECA4A2543.jpg
A little progress
it worked out pretty good with only a bit of fettling required for a good fit
http://i1056.photobucket.com/albums/t373/Eddie096/F17B67E6-9489-486B-A967-F9CF8DA789B0-520-0000006F215CF97E.jpg
A little progress
we also decided that 1 washer may not be strong enough so before fully welding we put another washer on top for good measure
http://i1056.photobucket.com/albums/t373/Eddie096/BAF9C227-D3A9-4D19-A0FD-583B02651D04-520-0000006F5B33B65F.jpg
A little progress
both in place
A little progress
zakboy
« Reply #76 on: October 14, 2012, 07:52:07 PM »
 hi scannerzer,  will you not need any rubber between the mounting's on the fame and engine brackets ?
« Reply #77 on: October 14, 2012, 08:17:45 PM »
Never used rubbers on any of mine Zak. Single washer's always worked fine too, but peace of mind's worth spending a little extra time on.  Wink
Nice work chaps.
zakboy
« Reply #78 on: October 14, 2012, 08:40:18 PM »
Nice work chaps.
i just wandered as i think the only reliant trike i owned had a engine kind of ruber mounting between the engine bracket and the bracket on the frame just thought it might have cut down on any vibration
« Reply #79 on: October 14, 2012, 08:54:32 PM »
Vibration's not been a real problem with mine.
Most of the bikes I've owned, (mostly Brit twins & 70s/80s Japs), have had solidly mounted engines. Similar vibration levels. No problem.  Smiley
« Last Edit: October 15, 2012, 06:10:00 PM by Manky Monkey » Logged
« Reply #80 on: October 14, 2012, 09:52:58 PM »
Hopefully it will be ok without any rubber mount .All the posts I have read before starting have been solidly mounted so thats the way we went. If it is a problem we would have enough room to put a rubber mount in but that will be a last resort.
one arm bandit
« Reply #81 on: October 15, 2012, 09:08:16 AM »
ive got know rubber mounts and its fine, get a very slight vibration noise from the tank only when down shifting from 4th to 3rd? but ive got no rubber mounts on the tank either
« Reply #82 on: October 15, 2012, 10:10:28 AM »
Tube mitre ?..I take it you just use a piece of paper rolled up or an old toilet roll tube to make a template ?
« Reply #83 on: October 15, 2012, 11:00:14 AM »
It's a program on the Internet tube mitre .exe .it allows you to input
2 pipe diameter and the angle at which they meet. When you print it
out you get 2 lines on the page,one solid one dashed just cut along
the solid line and rap the paper around the tube then mark the line and
your ready to cut.seems fairly accurate
« Reply #84 on: October 15, 2012, 11:02:17 AM »
Like this
http://i1056.photobucket.com/albums/t373/Eddie096/F8F6C880-6D6C-441F-A84D-265702D89B94-520-0000006EAA66C3F6.jpg
A little progress
« Reply #85 on: October 15, 2012, 11:05:57 AM »
Thanks OAB it's nice to get some feedback on this
« Reply #86 on: October 15, 2012, 12:48:13 PM »
Like I said wrap a piece of paper round the tube,bit of cellotape to hold together ,remove from tube,place on / next to tube ,draw a pencil line,cut with scissors/ knife, job done,slide paper back over tube,mark your lines ? Don't need some computer ,praps I'm to old school ?..I musta watched to much Blue Peter ?..he,he..I'm enjoying your build guys ,keep it up..
« Reply #87 on: October 15, 2012, 08:45:30 PM »
Thanks Stinkey the encouragement always welcome
one arm bandit
« Reply #88 on: October 16, 2012, 01:11:53 PM »
ado scannerzer, im sure you know the layout of you frame by now, but sometimes you dont see things untill its to late, depending on the hight of your backbone(tank tube) it may be worth removing the cross member in front of the engine,, the strength will still be there as the engine mounts hold the frame rails,, but you may need to slide the motor forward to get it out, it may just save the paint on the frame Wink  just an observation
« Reply #89 on: October 16, 2012, 06:14:16 PM »
I see wot you mean OAB I'll have to have a look at that ,it isn't something I had given any thought to
