April 22, 2026, 01:35:16 PM *
Pages: 1 ... 14 15 [16] 17 18 ... 36
Author Topic: A little progress  (Read 160798 times)
« Reply #225 on: April 06, 2013, 10:53:02 PM »
axle location and rear bumper today
http://i1056.photobucket.com/albums/t373/Eddie096/2654810D-BFCF-442C-86CA-D715A85BD1DB-120-0000001344887A89_zps5d196bb4.jpg
A little progress
drilled the rear axle clamp
http://i1056.photobucket.com/albums/t373/Eddie096/E6AD8A69-3871-4B0E-B58E-6C9688CF8DB3-120-00000013570D2F0E_zps1e3d0d07.jpg
A little progress
and welded a pin to the axle to stop any possibility of the axle turning in the clamps
http://i1056.photobucket.com/albums/t373/Eddie096/B78486FD-B675-4D7F-9446-04575CEB61D1-120-000000134D0E08FA_zps1ce7d677.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/8D63A593-9B6F-46EB-B094-64E298BC9481-120-000000135FF9E49A_zps342512a3.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/659F1560-EABE-44A3-8FAA-7DB62901654A-120-000000136989E5EF_zpsf5d6e52a.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/21BF78AB-9C01-4CDD-9FB0-9579D3F03955-120-0000001379C5EC7D_zps8e1fc9e5.jpg
A little progress
bent up the rear bumper
http://i1056.photobucket.com/albums/t373/Eddie096/C4C9F3E0-654B-4E10-91A9-0D04AD6C366B-120-0000001381D9647D_zps46e0d8e8.jpg
A little progress
and welded it in place covering the axle locating pins making them invisable
http://i1056.photobucket.com/albums/t373/Eddie096/150320131131_zps01832dd3.jpg
A little progress
turned down 2 bar ends
http://i1056.photobucket.com/albums/t373/Eddie096/5666BFD2-21D1-46E7-998F-B2506420BB24-120-000000139BF98886_zpsd1400646.jpg
A little progress
and now have them fitted to the bars but my phone battery ran flat so no photo's  Embarrassed Embarrassed
hopefully get some in the morning
steven brock
« Reply #226 on: April 07, 2013, 09:35:48 AM »
I was thinking of drilling and tapping mine m8 later
« Reply #227 on: April 07, 2013, 10:27:28 AM »
it's just a precaution as the clamps are so tight i don't think they would move anyway,
are you going to drill the axle and tap it?
« Last Edit: April 07, 2013, 10:38:30 AM by scannerzer » Logged
« Reply #228 on: April 07, 2013, 10:42:53 AM »
it's just a precaurtion as the clamps are so tight i don't think they would move anyway,
I thought that, until my foot slipped off the clutch!
Now I have 1/2" square bars welded to the tubes locating into slots in the front clamp sections Smiley
steven brock
« Reply #229 on: April 07, 2013, 01:56:55 PM »
Yeah I may do then use a socket button cap screw to finish
« Reply #230 on: April 07, 2013, 03:38:13 PM »
That's why I always use this type of welded bracket to locate the axle! never had a prob. Morrag
« Reply #231 on: April 07, 2013, 09:45:05 PM »
http://i1056.photobucket.com/albums/t373/Eddie096/5FA44F8E-7F5B-4C3E-95C4-99DFB9D3403F-120-00000100EBB6F8B9_zps9f8cc195.jpg
A little progress
made a spacer from this to hold the bottom bearing in the headstock tight,didn't get picture of the spacer
as the phone was flat Embarrassed
http://i1056.photobucket.com/albums/t373/Eddie096/7A875985-1944-41E0-A5F1-D6BC9CA8692B-120-00000013ACB30B50_zpsc9fb72bb.jpg
A little progress
then made a cover to hide the spacer
http://i1056.photobucket.com/albums/t373/Eddie096/A9A3993A-68F4-417D-A7D8-AE2F525E3828-120-00000100CDBB039F_zpsc22042b2.jpg
A little progress
the steering stop and lock will be fitted to this
http://i1056.photobucket.com/albums/t373/Eddie096/CF2372A0-C3B9-42BD-AFAF-34C7281F2A31-120-00000100DBE01549_zpsad4b8803.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/E7CE45FD-7952-43F7-965D-B55DC1BDB01B-120-00000100E3E30D68_zps340eebbd.jpg
A little progress
bar ends and hand controls fitted
« Reply #232 on: April 07, 2013, 10:02:27 PM »
Fine progress Sir!
« Reply #233 on: April 07, 2013, 10:33:13 PM »
Going like a rocket!
« Reply #234 on: April 07, 2013, 10:36:01 PM »
Whoosh!
« Reply #235 on: April 08, 2013, 05:06:41 AM »
At this rate he'll be finished in no time  Cheesy
Nice one Eddie.
« Reply #236 on: April 08, 2013, 05:59:56 AM »
Thanks guys Smiley
« Reply #237 on: April 08, 2013, 01:58:08 PM »
slow down....still trying to work out the gear shift Roll Eyes
selecting reverse....push down on new gear stick to raise original stick in g-box. I get that, but it's the "sleeve" through frame thats foxing me. The rod passing through the sleeve would need to raise/fall Huh maybe im looking at it the wrong way Roll Eyes Cheesy
« Last Edit: April 08, 2013, 02:02:33 PM by trikerpete » Logged
« Reply #238 on: April 08, 2013, 02:01:29 PM »
Baffled me too Pete -so I stopped thinking about it.
« Reply #239 on: April 08, 2013, 02:58:43 PM »
The rod through the chassis sleve is at the same level as the point of rotation of the original gearstick ball. The upper rod is pivoted, so depressing the gear knowb raises the original stick and vice versa. The pivot arm moves forwards and backwards in tandem with the new gear stick, this provides an extra push pull on the original gear stick. The new gear stick can move up and down.
