April 05, 2026, 05:10:13 PM *
Author Topic: rear master  (Read 2594 times)
digger06
« on: August 27, 2012, 06:35:06 PM »
so,
what are we all using to brake the rear axle?
mines a landrover one i think, and tbh, the standard yamaha cyl i had on the old xj9 trike seemed to give a better feel,
anyone else use standard bike rear master cyls to brake a reliant axle?,
mine at the mo feels wooden, although, i admit everything is not yet really worn in
one arm bandit
« Reply #1 on: August 27, 2012, 07:10:23 PM »
3/4 landy clutch, all linked brakes, and im real happy with them, a bit of an acception though as its a heel brake
zakboy
« Reply #2 on: August 27, 2012, 07:21:09 PM »
have kept the original break master cylinder on the xs and its fine also kept the one on the last xs with drums on and the mot tester was surprised how quick the brakes locked up but i personally i use  the landrover 3/4 copy on my own in case i do a disk convertion again at some point,but have to admit my brakes on the xv are sh*t at  the moment because the pedal ratio isn't right
« Last Edit: August 27, 2012, 07:23:26 PM by zakboy » Logged
« Reply #3 on: August 27, 2012, 08:27:28 PM »
I tried the standard rear cylinder on my very first trike -an XS750 Yamaha with Reliant drums on the back. Couldn't get the brakes to lock up at all but sold the trike before I fixed the problem. Switched to discs after that.
« Reply #4 on: August 27, 2012, 09:06:15 PM »
Reliant drum brakes on mine with Landy master - lock the wheels easy!
« Reply #5 on: August 29, 2012, 05:17:52 AM »
Any large-ish cylinder from a bike will be fine on the reliant drum set up, but they aint got enough umph to shift a pair of caliper pistons.
kevsky
« Reply #6 on: August 29, 2012, 06:17:59 AM »
volvo axle with standard volvo discs and one sided brake drum for hand brake
nabsim
« Reply #7 on: August 29, 2012, 01:02:50 PM »
Both my reliant and VW had land rover type fitted, not sure what will go back with either though but that's cos unless I use heel brake I ain't got a spare foot Smiley
