zakboy
« on: July 15, 2012, 04:52:41 PM » |
hi all, decided to split the B stamp axle i purchased for the xv1100 to give it the once over,only to discover that the crown wheel has 42teeth and the pinion has 13teeth unless im missing or over looking somthing that dont make it a B axle ratio......no mater how mant times i divide the two sets of teeth its a very exspensive A stamp
« Reply #1 on: July 15, 2012, 05:40:13 PM » |
zakboy
« Reply #2 on: July 15, 2012, 06:27:54 PM » |
he could have mike........rang him this morning said i can split the other b stams hes got see whats in them.....its all the f***ing about i cant do with
« Reply #3 on: July 15, 2012, 06:34:51 PM » |
or he swapped the inners hopping you wouldn't notice or not expecting you to take it apart
zakboy
« Reply #4 on: July 15, 2012, 06:47:58 PM » |
well i know he has not had these axle in that long, and my thought are that this axle has not been apart for some time.... the first time i went to split it when i first brought it i gave up because one of the studs was seize in the diff housing rather than risk cracking the housing i left it, then today decided to put some heat on it and finale split it... i do have to say one thing the iners all be A ratio are the best iv seen with no wear or play......i have to give the break the benifit of the doubt untill i see what hes going to do about it
« Reply #5 on: July 15, 2012, 07:05:22 PM » |
whats he charging for an A axle,,
zakboy
« Reply #6 on: July 15, 2012, 07:45:16 PM » |
Hes over the top with his prices Mike i know some one who payed £175 for an A stamp off him
one arm bandit
« Reply #7 on: July 15, 2012, 07:49:16 PM » |
can you not mark the hub and uj conection and count the turns that way, i know that doesnt help you much now zac but when i buy one i want to make sure before i part with any spondoolies
zakboy
« Reply #8 on: July 15, 2012, 08:53:52 PM » |
you could do that way bandit but because i was striping it anyway and had not got it set up on the trike it was quicker and more accurate t to divide the crown wheel teeth by the pinion teeth 42 divided by 13 gives 3.23 = A stamp ratio
« Reply #9 on: July 16, 2012, 12:30:49 AM » |
« Reply #10 on: July 16, 2012, 12:19:00 PM » |
When you say stamped, is it actually stamped on the axles as I have never noticed any stamps on either of mine?
« Reply #11 on: July 16, 2012, 12:36:56 PM » |
its on a flat bit at the rear of the diff casing
« Reply #12 on: July 16, 2012, 12:56:55 PM » |
Must look what I have then
« Reply #13 on: July 16, 2012, 01:56:04 PM » |
i,m keeping my eye out for a cheap axle
« Reply #14 on: July 16, 2012, 03:06:35 PM » |
I've mixed & matched engines, gearboxes & axles from loads of different Reliants for trikes & never looked to see whether they were A or B ratio axles. It's possible they were all As, or all Bs, but to be honest, they all performed more or less the same.
