April 10, 2026, 12:04:26 AM *
Author Topic: moving a steering rack  (Read 11818 times)
fORGOTTEN
« on: July 03, 2012, 12:37:23 PM »
Right i need to move a steering rack forward by about 8" to fit a motor in a car im building.  anyone had to do this befor and would no the best way round it?HuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuh?
Will that pass S.V.A?
« Reply #1 on: July 03, 2012, 01:49:22 PM »
Well i think we need pics of what you got,
and what you want to do.
And welcome to the Madhouse.
« Reply #2 on: July 03, 2012, 02:59:23 PM »
it,ll bugger up the geometry if not done correctly ,, then it will steer like a stuck pig and be lethal,,,, Shocked Shocked
snafu
« Reply #3 on: July 03, 2012, 04:48:57 PM »
Assuming your going to leave the suspension in the same position moving the rack by 8 in is probably going to be very difficult to achieve and retain the correct / acceptable angles for the steering input, as spanners said,  probably easier to lose a couple of inches off the sump (if that’s the problem) and move the engine / trans  6 in. Wink
fORGOTTEN
« Reply #4 on: July 03, 2012, 06:58:20 PM »
what would happen if i moved the rack forward by the 8 inches keeping it at the same height and extended the steering arm's (bit the track rod ends go in) by 8 inches??
will try get some pic's to help explain to
« Reply #5 on: July 03, 2012, 07:36:16 PM »
youde loose a lot of ,lock, and make it feel very vague, and unresponsive,++++ how are you safely going extend steering arms they take a hell of alot more load/stress than you realise
fORGOTTEN
« Reply #6 on: July 03, 2012, 08:20:14 PM »
o right would it. um was eather gonna cut then and weld a piece in on get some made up that where longer
fORGOTTEN
« Reply #7 on: July 03, 2012, 08:22:42 PM »
*them
« Reply #8 on: July 03, 2012, 08:49:40 PM »
the longer the steering arm,, the more movement needed from the rack..
( i used to build ,BRISCA,, stock cars  Wink )
fORGOTTEN
« Reply #9 on: July 03, 2012, 09:00:30 PM »
o nice man, used to go watch that and coventry speed way as a kid.
so if i did make the steering arms long it would take me more turns on the steering wheel to get from lock to lock yeah??
« Reply #10 on: July 03, 2012, 09:40:15 PM »
in theory,, yes,, but,,youlle only get a limited movement out of a steering rack,, so you wont get enough turns to give you the same amount of lock as you have with the original steering arms..
fORGOTTEN
« Reply #11 on: July 04, 2012, 10:16:35 AM »
[/quote]
so insteed of like a 3 point turn your end up doing like a 10 point turn. hahaha
« Reply #12 on: July 06, 2012, 06:03:37 PM »
Wouldn't it be easier to modify the sump on the engine for the clearance you need?
« Reply #13 on: July 06, 2012, 06:11:35 PM »
Shortened Reliant Scimitar chassis with 4 door Moggy Minor bodyshell Kev. I don't think there's enough room to move the motor further forward or higher.
« Reply #14 on: July 06, 2012, 11:31:37 PM »
G ::)OOD  GOD,,  there,s some ideas about biut no picture,s and not enough information,,,
