OK, now to deal with the front wall.
Phunkie Project Portafold (caravan!!)
Remove the window and inner covering (pretty bad condition and has been painted over, and not very well)
Remove sealing foam and fittings.
Check to see what holes require filling.
Sand off all the glue from the inner covering and the badly crazed over painting on the lower section. A rotary wire brush on a drill seems to do the job pretty well.
The fibreglass around the window area is so thin that over the years it has distorted quite a lot. This could result in water ingress even when the window is closed and locked.
This remedied by cutting, from a piece of thick wood (read old acoustic parcel shelf), a shape to fit exactly where the window mounts and fix it to the frame.
Fibreglass laminate is then laid around the sides, up to about 2.5 inches round the “frame”. this will make it stronger in that area and straight.
The same treatment carried out on the rear wall on the bottom rail/hinge mounting area has also been applied here, including adding mount for the contact set for lighting.
The lighting cables have then been glassed in……..
……..before sanding and covering with a coat of bright white topcoat.
That’s it, for the moment, on the front wall.
Now to start on the side walls, first the left side.
First, as with the front wall, remove trim and window.
Then remove all the trim glue, with a rotary wire brush and electric drill. This came off quite easily.
Then to look at the hinge panel at the bottom. Due to a couple of reasons the two skins of this assembly had parted company.
Also at the end lower corners the fibreglass was breaking up.
The reasons for all this, a combination of partially seized hinges, not very good bonding along the edge and laminate being laid on gel coat finish with out keying first.
The end parts were cut away to uncover good fibreglass.
The top and bottom skins of the lower assembly were held apart and a generous amount of Sikaflex was injected in between, then the two skins taped together to “go off”.
After keying with a course sandpaper the end corners were laminated.
Then trimmed and sanded ready for a coat of “top coat”. The tape was removed from the Sikaflexed joint and also sanded.
The window received the same treatment as the front window opening.
Things are moving ahead quite well now, so next time the right side ………………
