November 10, 2025, 11:44:14 AM
General Tech
1 1/4 inch bends for exhaust
Topic: 1 1/4 inch bends for exhaust (Read 4869 times)
dobber
April 24, 2012, 02:34:23 PM »
looking for a few 90 degree bends to adapt a new reliant down pipe. hellish expensive on e bay. can the pipe be bent or is it too thin. also wanted to lathe a straight bit to cut in to bits to fit as a sleeve internally to keep it strong or will that effect flow. any help appreciated.
can i have it in 20 Min's?
Re: 1 1/4 inch bends for exhaust
April 24, 2012, 06:56:55 PM »
I usually use OJZ Engineering for pre-formed bends. I think they only do stainless & not the cheapest, but definitely the best service I've found. Bends normally work out about a tenner each.
I just cut a straight length of the same tube, slit it down it's length & pinch it up in a vice until it slips inside the exhaust to form a sleeve, then butt weld the pipe sections together.
http://www.ojzengineering.co.uk/product.php?product=3
April 24, 2012, 09:40:11 PM »
This guy is quite cheap,But his smallest seams to be 1.1/2"
http://www.ebay.co.uk/itm/290374650778?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
dobber
April 25, 2012, 07:57:58 AM »
checked him hunter, still 11 quid for 1 bend with postage
slippery
April 25, 2012, 08:26:15 AM »
try this place made to measure
http://www.unit17.biz/Custom%20Exhausts.html
April 25, 2012, 01:19:05 PM »
here dobber,, try these i used to use em,,
J P EXHAUSTS
goodall street
macclesfield
cheshire
sk11 7bd
phone 01625 511158
email
www.jpexhausts.co.uk
klogan45
Reply #6 on:
May 11, 2012, 06:23:16 PM »
Hi Dobber have you had any luck with the bends for your exhaust yet? If so where did you get fixed up? I'm looking for 1abd 1/4 inch but having a hard job finding any.
Regards
K
zakboy
Reply #7 on:
May 11, 2012, 07:07:50 PM »
you can get a 1.5 and then get some reducers off ebay
these do a 1.5 but i think that is the smallest they do the one displayed is not 1.5 but when you read the listing they do do a1.5
http://www.ebay.co.uk/itm/90-degree-Stainless-Steel-Mandrel-Bend-76mm-3-inch-/220757866080?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item336631b660
Last Edit: May 11, 2012, 07:16:45 PM by zakboy
