November 12, 2025, 12:44:48 AM *
Author Topic: reliant air filter.  (Read 6058 times)
skates
« on: March 19, 2012, 08:00:45 PM »
i want to fit one of them air filters that come out the side with the chrome covers. any idea what and where i get one?HuhHuhHuh
thebigdogsix
« Reply #1 on: March 19, 2012, 08:14:21 PM »
Not sure but is this what your after  Grin
http://www.mankymonkeymotors.co.uk/forum/index.php?topic=10903.0
« Reply #2 on: March 19, 2012, 08:20:11 PM »
i made mine out of an old K&N one of an old escort/cortina  just made and drilled a base plate to suit  ,,SIMPLE,S,,,,,,,   Wink
skates
« Reply #3 on: March 19, 2012, 08:22:48 PM »
i take it thats a bolt on and go jobbie
thebigdogsix
« Reply #4 on: March 19, 2012, 08:23:48 PM »
yes
skates
« Reply #5 on: March 19, 2012, 08:26:35 PM »
cool. how much does that filter stick out from the carb?
skates
« Reply #6 on: March 19, 2012, 08:29:24 PM »
that carb looks a bit differant from mine
thebigdogsix
« Reply #7 on: March 19, 2012, 08:32:47 PM »
give or take a few mm 60mm
its a standard carb with the water jacket cut off the manifold and carb turned 180 deg
skates
« Reply #8 on: March 19, 2012, 08:43:08 PM »
thank anyway mate but was gonna keep my set up and just fit a filter
one arm bandit
« Reply #9 on: March 19, 2012, 08:43:59 PM »
pan cake air filter, accuspark are selling the on flea bay for hs2 carbs about £7.50  Wink
skates
« Reply #10 on: March 19, 2012, 08:51:57 PM »
nice but i take it i will need to mod my carb to make it fit
one arm bandit
« Reply #11 on: March 19, 2012, 09:01:11 PM »
have you got the su carb?? if so it will be hs2 and the filter will fit. if youve got limeted space and the carb still faces inward toward the engine you could go for a 32mm cone filter, but to be honest if the carb hasnt been rotated 180 degrees stick with the stock as  anything other than stock would suck all warm air off the engine and preformace would drop considerably
skates
« Reply #12 on: March 19, 2012, 09:09:31 PM »
Iv got a cone filter on at the mo. it sits above my rocker box
one arm bandit
« Reply #13 on: March 19, 2012, 09:17:18 PM »
yeah i ditch it personally or rotate the heated manifold. with only 40hp you want them all Wink  is it a trike or car??
skates
« Reply #14 on: March 19, 2012, 09:42:00 PM »
It's a trike mate
