November 12, 2025, 03:06:03 AM *
Author Topic: Bending!  (Read 3044 times)
pieman
« on: March 17, 2012, 07:45:20 AM »
Any one know of a mandrel pipe bender for hire in the Alton/Basingstoke area it would need to handle 2" stainless.
RODeo
« Reply #1 on: March 18, 2012, 03:04:47 PM »
Try exhaust tube manufacturers? Thats a big ole' tube ! Or if its for an exhaust,you can buy the bends and tig them together ,maybe cheaper in the long run?
pieman
« Reply #2 on: March 18, 2012, 07:44:01 PM »
Non of the exhaust manufacturers are interested hence trying to do it my self its  a bumper for my VW trike
« Reply #3 on: March 18, 2012, 08:01:24 PM »
Try some Boat Chandlers/Builders,and/or Shopfitters or similar, they use large diam. S/S for handrails. You could pre-fab what you require from standard fittings probably, Tig welded,with polished our welds if necessary, Morrag
« Reply #4 on: March 18, 2012, 10:59:11 PM »
As Rodeo says, you can buy pre-formed bends & weld them together -that's what we did for my stainless truck exhausts. We used stainless wire in a MIG welder. OJZ Engineering supplied the bends & straight tube.
http://www.ojzengineering.co.uk/product.php?product=3
RODeo
« Reply #5 on: March 19, 2012, 05:25:23 PM »
Another way is to design it using a straight piece of tube,then use handrail fittings(bends etc) I've done this at work . You can get fittings 45 or 90 degrees,they fit really tight and butt up tight only showing the join line and the od is exactly the same od as the tube,not a big gap,and might not even need welding if you make the tube the main 'stressed part' of the bumper and the ends as trims,also available are caps for the ends.The bends slide  in to the tube about 2". I use a high strength glue to stick them together.....yeah it really works! Grin ,and not as bad as you think, to look at.Give me a pm if youre interested and I'll sort out more info etc.
« Last Edit: March 19, 2012, 05:28:23 PM by RODeo » Logged
pieman
« Reply #6 on: March 20, 2012, 11:35:57 PM »
Thank you one and all for your imput I have the tube ready to get to it So will have a play and when it goes pear shaped then will look at preformed stuff
