November 12, 2025, 12:21:50 AM *
Pages: 1 2 3 [4] 5 6 ... 9
Author Topic: ELECTRONIC IGNITION ; A HOW TO CONVERT GUIDE  (Read 40515 times)
RODeo
« Reply #45 on: January 21, 2012, 07:51:12 PM »
All good ideas there..I was wondering whether the post on the coil had been overtightened ,causing a crack between post and outer edge ?
skates
« Reply #46 on: January 21, 2012, 07:59:54 PM »
iv done it by the book. im stumped hereto why its sparking. the coil is right underneath my tank so it aint good
fifer
« Reply #47 on: January 21, 2012, 08:01:52 PM »
Have you sucked the flying saucer yet ?
RODeo
« Reply #48 on: January 21, 2012, 08:03:48 PM »
« Reply #49 on: January 21, 2012, 09:15:28 PM »
try your old coil
skates
« Reply #50 on: January 21, 2012, 09:18:32 PM »
now thats just rude
« Reply #51 on: January 21, 2012, 09:20:29 PM »
is it the two wire system Huh?
red +positive from  feed at coil to unit in dizzy and a black   (trigger wire )  that returns to  neg - side of coil Huh
« Reply #52 on: January 21, 2012, 09:30:19 PM »
what coil are you using
skates
« Reply #53 on: January 21, 2012, 09:46:37 PM »
yep thats the one
skates
« Reply #54 on: January 21, 2012, 09:48:28 PM »
i bought the whole set off ebay
http://www.ebay.co.uk/itm/110669216292?ssPageName=STRK:null:IT
« Reply #55 on: January 21, 2012, 09:54:07 PM »
i know it sounds ,,daft,, but check youve got the polarity right  and check the quality of the connection of the ,,trigger,, wire at the coil
it would be interesting to check each side of each connection/joint in the wiring with a volt meter..
skates
« Reply #56 on: January 21, 2012, 09:56:55 PM »
did that about 5 times. what i really need to know is why its sparking from the live wire at the coil
fifer
« Reply #57 on: January 21, 2012, 10:05:00 PM »
Originally posted by fifer ; Today at 07:31:11 PM
Posted by: fifer
Have a wee look at the distributor again .
Suck on the vacuum tube end on the flying saucer and check that the points plate moves .
Take the distributor out if you cannot get access to suck .
If the end of the flying saucer lever is not located in the points plate peg on the underside of the base then the points plate will not be in the correct position relevant to the rotor /pickup .
Originally posted by skates  ;
now thats just rude
It was a serious query as to my 1st post above .
« Reply #58 on: January 21, 2012, 10:07:52 PM »
its unusual thats why i asked about volage 12volt low tension shuold find it hard or shouldnt jump like that unless there,s a crack or a damp track for it to follow .
where as high tension I.E.. coil king lead or plug lead will jump that distance easly,
could do with a couple of ,snap shots, of youre set up ,, may be able to spot something,
« Reply #59 on: January 21, 2012, 10:11:09 PM »
Because all that voltage has to go somewhere!
You apply 12v to a coil of wire wrapped around an iron core, this induces an increase in voltage on the primary windings.
When the points open, or the module switches, the voltage is released, this causes a drop in voltage on the primary windings.
This voltage drop induces a current build up in the secondary windings, which are coiled over the primary ones, because there are many more coils in the secondary set than the primary set the voltage is much higher.
The secondary winding is connected directly to the king lead, and this is where the spark should go.
Your coil is either faulty with a break in the windings or your module isn`t switching.
