November 11, 2025, 07:44:56 PM *
Pages: 1 ... 5 6 [7] 8 9
Author Topic: ELECTRONIC IGNITION ; A HOW TO CONVERT GUIDE  (Read 40464 times)
RODeo
« Reply #90 on: January 28, 2012, 11:23:36 AM »
Question for Fifer.....Is it still possible to use the sliding type points ,even though I have cut the post off to fit the module? Also.. Is the coil that is compatible with the elec ign (new 12v) compatible with the points? Wondering cos I want to carry a set of points and a condensor as spares,and have found a sliding set in the garage !Otherwise I will order a set of early points that will fit without the post.
« Reply #91 on: January 28, 2012, 01:07:09 PM »
The early Red points unfortunately do not fit the Blue point baseplate . Sad
I will upload piccies of baseplates for both types and point out why one does not fit the other
This peg HAS TO BE REMOVED .
This does NOT APPLY to all earlier distributors with the fixed contact points
as they do not have the peg .
If an earlier points baseplate can be obtained it means that you
could keep your pegged points baseplate intact should
you want to revert back to points
Sad
The blue sliding points are much better at preventing wear than the Red points due to the fact that the smaller face can slide up and down over the other point face thereby reducing the time it takes for the mountain and the valley pitting to occur on the points faces .
If you fit the Blue points with the peg cut off then the points faces will not be central but will be at the bottom of the other fixed point face .
I have not run one that way before so I do not know how the points would perform .
Can you not just get hold of another blue point baseplate and that way you can have the points and condenser pre-mounted on the plate .
Only a matter of removing the two baseplate securing screws and dropping the points setup in
If only carried as a spare then the Red set will be perfectly adequate
I have a few spare Red points plates here and you are welcome to have one free .
Just PM me your address or even better e-mail me at fiferonmankymonkeymotors@gmail.com and I will post it down to you .
The coil will work perfectly well with points .
« Last Edit: January 28, 2012, 11:22:36 PM by fifer » Logged
skates
« Reply #92 on: January 28, 2012, 03:05:27 PM »
woo hoo trike is all up and running tho i think she is running a bit hot as there is a little steam coming out of the hole in the back of the engine block
« Reply #93 on: January 28, 2012, 04:17:24 PM »
what hole  Shocked
RODeo
« Reply #94 on: January 28, 2012, 04:27:29 PM »
Great news Skates,was wondering how you were getting along with it! No need for me to come down now then?
 What hole ?? Core plug leak?
« Last Edit: January 28, 2012, 04:29:06 PM by RODeo » Logged
skates
« Reply #95 on: January 28, 2012, 05:28:51 PM »
there is a small hole at the back of the engine on the block. i think its where the thermostat is
« Reply #96 on: January 28, 2012, 05:41:15 PM »
what on the l/hand side at the back. below the exhaust manifold.
that's the cylinder block cooling system drain hole. there should be a plug in there
« Last Edit: January 28, 2012, 05:43:43 PM by terry t » Logged
skates
« Reply #97 on: January 28, 2012, 05:42:42 PM »
right in the middle of the block just underneath the rocker cover
« Reply #98 on: January 28, 2012, 05:44:40 PM »
on the cylinder head
skates
« Reply #99 on: January 28, 2012, 06:38:26 PM »
yep
« Reply #100 on: January 28, 2012, 06:47:29 PM »
yep
on the back. of the head
RODeo
« Reply #101 on: January 28, 2012, 07:45:16 PM »
Im confused guys! Grin
« Reply #102 on: January 28, 2012, 07:53:16 PM »
so am i  Huh
is it this one.the small one in the middle
RODeo
« Reply #103 on: January 28, 2012, 08:09:08 PM »
From memeory,thats a sort of angled hole? I was wondering if he had a hole in the core plug!
« Reply #104 on: January 28, 2012, 08:19:34 PM »
yes its an plug for a oilway end.
and if theres steam or water coming from there. hes got real problems.
