June 04, 2026, 12:14:47 PM *
Pages: 1 2 [3] 4 5 ... 48
Author Topic: Rennies Trike  (Read 350236 times)
nabsim
« Reply #30 on: November 16, 2011, 02:09:46 PM »
Theres no kettle in wonderland is there, we never saw one did we dobber? Smiley
You look awfully familiar in that pick Andy, did you used to lived in/near Buxton?
andyrennison
« Reply #31 on: November 16, 2011, 04:35:38 PM »
Hi Nabsim
Nope, not me. I didn't do it.  It was HIM officer (points finger and runs away)
Been there a few times socially is all.  Born in Rochdale and moved to Bury 25 or so years ago.
« Reply #32 on: November 16, 2011, 09:25:03 PM »
  Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy
so much to see,,,,,,,
you all walked past   the blo#dy kettle,,,,
now thats a first  Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy
andyrennison
« Reply #33 on: November 27, 2011, 10:13:22 PM »
Has anyone any tips for getting hubs off the half shafts?  so far all the follwing have failed:
1. A Draper hub puller, heat on the hub. and a big hammer (broken hub puller)
2. Modifying my hydraulic pipe bender to make a hub press (steel of the pipe bender is flexing)
3. Swearing and ranting
« Reply #34 on: November 27, 2011, 10:27:26 PM »
Dunno but heating it on a barbecue doesn't work!  lol
« Reply #35 on: November 27, 2011, 11:12:22 PM »
Na you went wrong by swearing and ranting at it. Shocked
get the offending shaft. and take it to your local garage and ask them if they got a 20 ton press.give then a few bob and let then swear at it.sorted  Grin
« Reply #36 on: November 27, 2011, 11:15:13 PM »
if there that tight the only way is a 20 ton plus press. leave the nut on so it does nut damage the thread
« Reply #37 on: November 27, 2011, 11:22:25 PM »
Ditto to Terry T, and stand clear when they let go!!!!
andyrennison
« Reply #38 on: November 29, 2011, 11:17:59 PM »
Ha ha.  So we tried and tried with a clarke slide hammer, the shafts wont come out either - grrrrrrrr.  Bigger slide hammer needed methinks.
andyrennison
« Reply #39 on: November 29, 2011, 11:25:17 PM »
Spent the evening cleaning my head, here are a few before and afters, evening well spent methinks
andyrennison
« Reply #40 on: November 29, 2011, 11:34:23 PM »
Not a finished job, but clean enough to start the polishing up.  Valve compressor comes tomorrow, then they can come out and be cleaned and reseated with new seals
andyrennison
« Reply #41 on: November 29, 2011, 11:38:33 PM »
It was a mess !  Cry
dobber
« Reply #42 on: November 30, 2011, 01:47:53 AM »
nice.
 i left a blow torch on hubs, cut off back plate with a cut off disc then used some box bar against back of hubs with a lump hammer while rotating hub.
   oh what fun.
        can i have it in 20 Min's?
« Reply #43 on: November 30, 2011, 09:51:24 AM »
Yeah, it's usually the bearings that stick in the ends of the axle tubes. As Dobber says, if you're going for disc brakes & don't need the drum back plates, cut 'em off so you can get a clear shot at the hub. Then use a chunk of wood against the back of the hub & a few sharp whacks with a heavy hammer to loosen them. Turn the axle to hit alternate sides of the hub & try to avoid the corners cos you don't want to break 'em off! The hubs should drift out with the shafts attached.
Nice clean head you've got there Andy. As I'm sure you know, the valves are held with a pair of tapered "collets" that sit in a groove in the valve stem, above the spring. If you haven't got access to a spring compressor, you can remove them by putting a small block of wood against the valve head in the combustion chamber, then placing a suitable sized socket on the washer on top of the spring & giving it a sharp whack with a hammer. That compresses the spring enough to dislodge the collets. Best done with a rag over the spring to catch the collets though, cos they will ping out, ricochet off the ceiling of your shed & never be seen again. Yeah, I speak from experience.  Sad
« Last Edit: November 30, 2011, 10:04:31 AM by Manky Monkey » Logged
« Reply #44 on: November 30, 2011, 11:18:06 AM »
A perfect pingfukit moment!
