June 03, 2026, 06:37:12 PM *
Pages: 1 ... 44 45 [46] 47 48
Author Topic: Rennies Trike  (Read 349393 times)
« Reply #675 on: August 17, 2014, 09:22:34 PM »
tidy Andy nice way to do it
« Reply #676 on: August 17, 2014, 09:25:55 PM »
Very neat and tidy. Smiley
« Reply #677 on: August 17, 2014, 09:43:06 PM »
Thanks guys Smiley
« Reply #678 on: August 19, 2014, 07:55:36 PM »
Looking good Andy.I didnt use any cable on the choke.I hold the choke open by hand.
« Reply #679 on: August 24, 2014, 07:57:20 PM »
How did you manage that while riding alon and at lights etc! Smiley
« Reply #680 on: August 24, 2014, 07:59:57 PM »
2 days to build a battery box! Mind you that did include making a sheet metal Break into my bench. Ran out of welding wire as well so trip to somewhere tomorrow to get some more. Pics tomorrow night when I'm done
« Reply #681 on: August 24, 2014, 08:14:59 PM »
You too! Trouble is it's a bank holiday, so the only place near me will be Halfrauds.
« Reply #682 on: August 24, 2014, 09:50:57 PM »
Yep, same here. Ah well, at least I can do a bit more then.
« Reply #683 on: August 25, 2014, 12:09:19 PM »
Andy..I hold the choke open on start up, let the engine warm up a bit then close choke before moving off.Never had a prob.mixture is set correct, so isnt running too rich etc.Mostly only ride on warm days, so that probably helps as well!
« Reply #684 on: August 25, 2014, 01:40:07 PM »
Wow, I remember my old reliant 750 (3/25 Deluxe!) took for ever to warm up and not need the choke, mind that was a zenith carb and the heater was usually on most of the time Smiley
« Reply #685 on: October 26, 2014, 11:06:10 PM »
Been a bit quiet recently here. Had to clear out my Mums house to sell it and empty all my Dads tools etc which has been quite upseting.
Anyhoo, I decided to get some Trike Builds therapy this weekend. So made up the panels to go over the electrics box and around the handbrake.
Here is the electrics box I made up fitted, need to make a rubber seal for the edge yet..
« Reply #686 on: October 26, 2014, 11:08:04 PM »
And here it is with all the panels fitted, and the new seat balance in place.
I'm much happier with this seat than the other one I mde, and it has the advantage that the little radio fits into the purpose made void behind my back!
« Reply #687 on: October 27, 2014, 11:11:29 AM »
Looking good.Do you think the seat base needs to be slightly narrower about half way along? May chafe your thighs after a while? just a thought.
« Reply #688 on: October 27, 2014, 09:07:01 PM »
Possibly. I'll sit and bounce a bit once it is fixed in place. I didnt glue the bottom rails in in case i needed to alter it Smiley
« Reply #689 on: October 28, 2014, 12:27:59 PM »
A radio ! Next thing you'll be adding is air con.  Cheesy
All looking very smart.
